Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 49 of 49
  1. #41
    New ROGer Array
    Jan 2019
    2
    Quote Originally Posted by mariozamoramd View Post
    It's been exactly a month from when I tried plan C. Seems to be working so far. No Nitrous powered fans making airplane engine noises for now. Let's hope it works for good.
    Thank you. I will try this too then
  2. #42
    New ROGer Array
    Apr 2020
    4
    Follow-up to Previous Posts : Beware, the problem will return.
    Twice the problem has returned.
    This time, I did the following:
    1. Remove and reinsert the wire going to the left fan.
    2. Remove and reinsert the wire going to the right fan.
    3. Disconnect and reconnect the battery.
    That's it. I'm going to bet that 6 weeks from now these steps will need to be re-applied. The application of the electrical tape may just be a red herring.
    I know very little about electrical circuitry, but I bet the problem has something to do with some sort of electrostatic build-up related to the battery. I first got the problem after the laptop had been left unplugged and off for a few months. I don't remember what the battery state was when I turned it on, but the fans went crazy as soon as I started it up.
  3. #43
    New ROGer Array
    May 2018
    5
    Angry The return of the problem. The fans strike back.
    Quote Originally Posted by Galahad56 View Post
    Well well. I guess after 2 successful months the problem returned. Running out of options, other than unplug-plug method which we all have to do periodically like the post above. Hate ROG. I actually consulted and brought my unit at the ASUS service center and they just claimed my BIOS is not updated so they check it is updated. They cant seem to figure out what's wrong and offered to ship my unit somewhere for checking but warranty is already expired thanks to COVID lockdown. So I guess I'm stuck with sh*tty device.
  4. #44
    New ROGer Array
    Sep 2018
    2
    Can we just have a fan control app
    I have this ROG GL-503GE with me for 2 years, it has been performing well, but recently, I am having this fan running at 7400RPM even when idle. The noise is just unbearable. Reading down the threads, I found out that it isn't an isolated case at all, many is suffering from the same issue. Can Asus just make a fan control app to make the life of all of us a bit easier?
  5. #45
    New ROGer Array
    Jul 2020
    18
    106
    Quote Originally Posted by madbty View Post
    I don't know about your model but Armoury crate You can modify the GPU and CPU fan speeds via the manual setting.
    https://www.asus.com/supportonly/Arm...Desk_Download/
    If the software detects and supports of course.
  6. #46
    Moderator Array
    Feb 2019
    14
    705
    Hello madbty,
    Please kindly send your device to service center for further examination.
    It is not about fan control. Thermal needs to be checked as well.
  7. #47
    New ROGer Array
    Sep 2018
    2
    I have tried the below as suggested in previous threads, it worked for me now, right now at 52C the fan speed is at 2600 RPM, when I was playing dota2, temperature went up to 80C and fan speed at 5400 RPM. It will leave it like this for the time being, may take it to service centre after the pandemic.
  8. #48
    ROG Member Array
    Jan 2018
    11
    Quote Originally Posted by Blake@ROG View Post
    Hello madbty,
    Hello, I really don't think its about thermals, the fans ramp up with the computer doing absolutely nothing. Any third party app that can check the temps show they are at normal idle range, so unless the device is just plain unable to detect thermals reliably i think its and issue with faulty hardware in a whole batch since its not a one off issue and happens to many people. The only workaround with the wires only solves it for awhile, then it comes back and is as annoying as ever.
  9. #49
    ROG Member Array
    Jan 2018
    11
    Quote Originally Posted by KorosuKivy View Post
    Sadly only newer models have the manual control older ones have nothing. Tried it on mine - no options to control the fans.
Tags for this Thread
