Results 1 to 8 of 8
    ROG Guru: White Belt Array Thomas extreme gamer PC Specs
    MotherboardROG MAXIMUS XI EXTREME
    ProcessorIntel Core™ i9-9900K
    Memory (part number)32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
    Graphics Card #1GeForce RTX™ 2080 Ti ROG-STRIX-RTX2080TI-O11G-GAMING
    Sound Cardon board
    MonitorROG PG279Q
    Storage #1Samsung 1TB 970 PRO
    CPU CoolerROG RYUJIN 360 6x NF-F12 IPPC 3000 PWM 140mm, 3000 RPM
    CaseView 91 Tempered Glass RGB Edition 6x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM
    Power SupplyCorsair AX1600i Digital, 80 PLUS Titanium 1600W
    Keyboard ROG Horus GK2000 RGB
    Mouse ROG Sica
    Mouse Pad ROG Scabbard
    OS Windows 10 pro 64 bit (1903)
    Accessory #1 custom built pc from AVADirect
    Jul 2017
    110
    Are the Noctua fans NF-A14 ippc-3000 PWM fans static pressure fans airflow or can the
    Are these fans static pressure or both?
    https://noctua.at/en/nf-a14-industrialppc-3000-pwm
    Are they aio radiator fans, case fan or can they be used both?
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    https://noctua.at/en/nf-a14-industri.../specification
    140mm x 140mm x 25mm
    So yes, can fit anywhere and everywhere a standard 140mm PC fan will fit (same mounting dimensions/geometry/holes/etc). They're also compatible with 120mm mounts/holes/etc, if there's enough space for them. I've used them in many systems, including the one listed in my profile PC specs (2 on CPU cooler, 2 front intake, 2 side intake, 1 rear exhaust, 1 top exhaust), they keep the inside of the box surprisingly "cool" even when running hours of nonstop torture/stress in a 35C ambient.
    Rated airflow (~3000rpm) = 269.3 m³/h = 158.5 CFM
    Rated pressure (~3000rpm) = 10.52 mmH20 = 0.15 PSI
    Rated 800~3000rpm, the rotor geometry is balanced so that fewer rpms will diminish airflow at a faster rate and air pressure at a slower rate. Meaning they're optimized for enclosed rack environments, they push hard instead of pushing more.
    They can be forced to spin down to ~400rpm (hard on motor) but then they sound like choppy little helicopters.
    They can be overvolted up to >3600rpm (hard on motor and on bearing) but then they sound like little space shuttles.
    Beware that at full rpms they draw 0.55A @ 12V = 6.6W each.
    So basically only one fan per (1A @ 12V = 12W) mobo fan header, if you want a bunch of them in a push-pull rad setup then you'll need a bunch of mobo fan headers and/or other fan controller hardware.
    The 2000rpm version is a far better choice for sane people, much quieter and much more power efficiency.
    https://noctua.at/en/nf-a14-industrialppc-2000-pwm/specification
    [/Korth]
    Sound Cardon board
    MonitorROG PG279Q
    Mouse ROG Sica
    Jul 2017
    110
    Quote Originally Posted by Korth View Post
    How many of the fans do you think about six *of these fans on the case?
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    What are you trying to accomplish?
    What case?
    What MOBO?
    What CPU?
    What GPU?
    Personally I got better performance from the Corsair ML Pro fans that draw a lot less current.
    Sound Cardon board
    MonitorROG PG279Q
    Mouse ROG Sica
    Jul 2017
    110
    Quote Originally Posted by JustinThyme View Post
    What case?
    What MOBO?
    What CPU?
    What GPU?
    I am trying to get 5ghz over lock on intel 9900k. Going to be using system for gaming.
    Case Thermaltake View 91 *https://www.thermaltake.com/Chassis/...ion/design.htm
    *Motherboard Asus Maximus XI Extreme*
    https://www.asus.com/us/Motherboards...US-XI-EXTREME/
    CPU Intel 9900k
    GPU Asus ROG Strix 2080ti oc edition
    https://www.asus.com/Graphics-Cards/...O11G-GAMING/**
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    What are you using for the primary cooling? air only? You don't need high pressure if the fans aren't on a radiator. Just enough air flow in the right places like inlet blowing into the GPU and an inlet in the rear to the CPU. Then out the roof.
    Case comes native with 3 in the front or intake and one out the back for exhaust the would give you positive pressure and allow the excess to be pushed out the top and other open areas.
    Looking at your case (nice one too!) its meant for WC with two rads where the pressure is more important than flow.
    If I was you and I was going for air cooling Id buy 3 more fans to go out the roof and reverse the rear fan to be an inlet and leave the front as is.
    Unless you just want overkill and different fans. Ive tried the Noctura fans and not a big fan of the fans....uh what...yep. There is one place where they made a difference for me and that was as a replacement for the fans in my NAS because the stock fans were horrendous in both air flow and noise levels in a Synology DS3018XS. The 7200 rpm drives are loud enough, dont want fans that can drown that out!
    You CPU cooler and its fan are much more important, what are you using there?
  7. #7
    Sound Cardon board
    MonitorROG PG279Q
    Mouse ROG Sica
    Jul 2017
    110
    Thanks for responding Justin!!! I am using Asus ROG Ryujin 360 AIO with 6 Noctua NF F12 industrialIPPC-2000 PWM on the radiator.
  8. #8
    Sound Cardon board
    MonitorROG PG279Q
    Mouse ROG Sica
    Jul 2017
    110
    Quote Originally Posted by Thomas extreme gamer View Post
    Still waiting for reply!
