Results 1 to 6 of 6
Thread: Claymore Num Lock Light
11-22-2018 12:51 AM #1
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 15
Is there a way to disable the white light of the num lock when the num lock is on, or even change it to a different color? its really annoying at night and in a dark room. Also if theres a way to disable/change the caps lock light that would be great as well.
11-22-2018 01:24 AM #2
Do you need to lock the num keys and caps while playing games? The only way is to toggle the lock keys if you don't want to see them.
Somebody was having an issue where a particular USB hub disabled the lock LEDS, pretty sure he'll be willing to sell it to you
11-22-2018 01:30 AM #3
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 15
i only use my num pad for actual numbers, calculator and excel related stuff. before i updated the firmware the numpad did not light at all, now that i know the numlock light is always toggled to on, im regretting the firmware upgrade
asus should at least give the option of disabling the light all together or even let you choose what color it toggles on as like a less bright color, red.
11-22-2018 01:37 AM #4
The LEDs for lock keys will always light up regardless of which firmware you're on.
Thanks for the suggestion about changing their color.
12-13-2018 01:19 PM #5
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 1
12-14-2018 01:52 AM #6
It is too late to change the colors now, but we'll certainly take it into consideration for future models. Thanks.
