11-22-2018 09:15 PM - last edited on 03-06-2024 07:28 PM by ROGBot
11-22-2018 11:30 PM
11-23-2018 08:25 AM
HiVizMan wrote:
Please check all PSU connectors are correctly fitted.
Make sure all CPU connectors have been used and not PCie connectors for example.
Clear CMOS
If all else fails remove everything including the CPU and motherboard from your case and place mobo on box it came in and use that as a work bench. Fit CPU again, one stick of ram and VGA.
11-22-2018 11:37 PM
11-22-2018 11:51 PM
11-24-2018 07:47 AM
SrAbsolution wrote:
Hello, I am just installing my new motherboard and cpu, I bought a crosshair vii and a 2700x and have paired it with my rtx 2080,at the time of powering on im getting no post and no video, board shows number 8 on the left side nothing to the right.
I Have tried reseating my rtx and moving ram to different dim slots and even just keeping 1 ram stick.
Ram and rtx work as i used to use them on my Intel build before switching. I am in serious need of help.
I am using 2 3000mhz 8gb corsair rgb vengeance
11-24-2018 10:02 AM
11-25-2018 12:15 AM
11-25-2018 01:06 AM
11-25-2018 02:24 AM
