Results 1 to 3 of 3
    ROG Member Array
    Nov 2018
    5
    Question MAXIMUS XI Extreme NVMe M.2 heat sink
    Installed 2 970 EVO on the motherboard underneed the M.2 heat sink. On the backside there is some material added "LAIRD" (to help to reduce heat i think) but my question is : do we need the green label ?
    Regards
    Michel
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,805
    No, you should remove the green label. Yes, it's a thermal pad.
    ROG Member Array
    Nov 2018
    5
    Thanks
Tags for this Thread
