Results 1 to 4 of 4
    ROG Member Array
    May 2018
    Rog gl502vs-us71 battery problem
    I've been having some troubles with the charge while playing. When processor is pushed charge just starts constantly disconnectind and re-connecting while plugged in. Also gets very hot and loud playing really not demanding games such as CS GO or Fortnite.
    I've been told that it is a charger problem because it is not original and supports a smaller amperage than it should. Could you tell me the details for the original charger for my laptop? Including pin size, so I can buy a new one if necessary. It is a GL502VS-US71 IntelCore i7 7th gen, gtx1070, 16gb ram, 128ssd 1tb hard, 60hz display+g-sync
    The current charger I use: INPUT: 100-240 V - 1.7 A 50-60hz
    OUTPUT: 19.5V = 6.15 A 120W
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    45
    337
    19.5v /11.8A (230w) should be enough. The first revision of the GL502VS used to ship with a 180w power supply, then they changed it to a 230w one.
    This + updated bios should fix the problem.
    ROG Member Array
    May 2018
    Quote Originally Posted by FULLMETALJACKET7 View Post
    Thank you!
    ROG Member Array
    May 2018
    Do you think it will fix the high temperatures? Should I change the battery as well?
