Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    45
    363
    Use k5-pro instead of thermal pads. By using high performance thermal pads you're dumping even more unnecessary heat into an already saturated cooling solution. VRM's can safely work a LOT hotter (usually up to 120C) than cpus and gpus, so don't bother trying to cool them down even more. Not gonna get any performance gains by doing so.
  2. #12
    ROG Member Array
    Apr 2019
    13
    Thanks for the recommendation and input👍
  3. #13
    ROG Guru: White Belt Array
    Jul 2013
    11
    117
    mine is still holding up since then. i am even doing VR games on it
  4. #14
    Jul 2013
    11
    117
    Quote Originally Posted by FULLMETALJACKET7 View Post
    should i switch my pads with k5-pro?
  5. #15
    Mar 2018
    45
    363
    Quote Originally Posted by TX2000 View Post
    If it's good enough for you the way it is right now, don't bother.
Tags for this Thread
