Results 1 to 6 of 6
    ROG Member Array Tekred PC Specs
    Tekred PC Specs
    Laptop (Model)Some Asus model i use for school
    MotherboardAsus Zenith Etreme x399
    ProcessorAMD Threadripper 1950x
    Memory (part number)f4-3200C16q-32GTZR (G.Skill TridentZ 32gb)
    Graphics Card #1Asus Rog Strix 1080
    Sound Cardon board
    Storage #1Samsung 970 EVO m.2 250gb (x3)
    Storage #2WD 1tb
    CPU CoolerEnermax Liqtech tr4 360mm (temp)
    CaseIn Win 303c
    Power SupplyEVGA G1+ 850 gold
    Tekred's Avatar
    Jun 2018
    17
    Project ReVolt Sponsored Build
    Hello Everyone,
    This is a build I recently completed. Feedback is welcomed
    First I would like to thank my sponsors; InWin, Bitspower, and Teamgroup for making this build possible.
    About the Build
    This is a re build of a previous project I had. The PETG tubes had some issues which caused it to leak and frying my gtx 1080. So I stripped the build and salvaged what I could and through the PETG in the garbage and decided I would go back using acrylic tubing. I tried to keep this build simple but with attitude, and orange being my favorite color I was really wanting to do a build using orange. I didn't want it to look Halloweenish so I decided to go with white and orange with some black accents. The 303 chassis by InWin is a really fun case to build/mod in and I would recommend it to anyone looking for a mid size chassis with plenty of space. I modded the case with a front window so the watercooling can be viewed from the front. I also added 4 120mm fans to the roof, which I painted to match the build. Overall the build took way longer than expected and I ran into many issues along the way and that's where the name Revolt came from. Hope you guys enjoy the photos!
    Hardware
    Asus Zenith Extreme x399
    Asus Strix gtx 1080 ( replacing with a new 1080)
    Teamgroup Nighthawk RGB 32gb @3000mhz
    EVGA Supernova 850 G1+
    Inwin 303c white
    Inwin Polaris RGB (Custom Painted)
    Custom sleeved cables by me
    Watercooling by Bitspower
    TR4 waterblock
    GTX 1080 waterblock
    16mmOD Crystal Link Acrylic tubing
    200mm Res + DC pump combo (custom painted)
    Hex flow indicator (custom Painted)
    360mm x 55mm Radiator (custom Painted)
    delux white fittings, many of them
ID:	77276Click image for larger version.
ID:	77274Click image for larger version.
ID:	77273Click image for larger version.
ID:	77272Click image for larger version.
ID:	77271Click image for larger version.
ID:	77270Click image for larger version.
ID:	77269Click image for larger version.
ID:	77268Click image for larger version.
ID:	77267Click image for larger version.
ID:	77266Click image for larger version.
ID:	77265Click image for larger version.
ID:	77261Click image for larger version.
ID:	77264Click image for larger version.
ID:	77263Click image for larger version.
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    Looks cool. I like the route you went with the outlet off the pump. May I ask what went wrong with petg tubing? Only leaking I've heard of is from the fittings. Not the petg itself. Or am I misreading?
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,801
    Some intricate pipework there, nice build.
    Tekred PC Specs
    Sound Cardon board
    Storage #2WD 1tb
    CaseIn Win 303c
    Tekred's Avatar
    Jun 2018
    17
    Quote Originally Posted by feedmeink View Post
    Thank you, and yes that's exactly what happened. The PETG tubing I guess heated up causing it to shrink at the fitting due to the compression of the o ring. I have build coming up for Thermaltake and they sent me 40 meters of 16mm OD PETG hope I don't run into this issue again lol
    Tekred PC Specs
    Sound Cardon board
    Storage #2WD 1tb
    CaseIn Win 303c
    Tekred's Avatar
    Jun 2018
    17
    Quote Originally Posted by Silent Scone@ASUS View Post
    Thank you that's what I was going for lol
    ROG Member Array jimsond PC Specs
    jimsond PC Specs
    Laptop (Model)G75VW
    MotherboardASUS RAMPAGE V EXTREM
    Processori7-5930K Haswell-E 6-Core
    Memory (part number)G.SKILL Ripjaws 4 series
    Graphics Card #1EVGA GeForce GTX 980 TI Hydro Copper Signature
    Graphics Card #2EVGA GeForce GTX 980 TI Hydro Copper Signature
    MonitorASUS ROG Swift PG278QR 27
    Storage #1OCZ Technology 256GB Vector Series SATA 6.0 GB Raid0
    Storage #22 Samsung Evo 860 1TB
    CPU Cooler2- Swiftech MCP655 pumps & Bitspower BP-2D5TOPP-BK Dual D5 Mod Top
    CaseCorsair D900 Custon water cooled!
    Power SupplyATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified
    Keyboard Logitech G15 Gaming Keyboard
    Mouse Logitech G9
    Headset ASTRO Gaming A40 TR with MixAmp Pro TR
    Mouse Pad Logitech G13 Advanced Gameboard
    OS Windows 10
    jimsond's Avatar
    Mar 2012
    33
    22
    Very nice and well put together built!!
    ASUS RAMPAGE V EXTREMIMG
    G.SKILL Ripjaws 4 series 16GB (4 x 4GB) 288-Pin DDR4 SDRAM DDR4 3000
    2- EVGA GeForce GTX 980 TI Hydro Copper Signature
    EVGA 120-G2-1600-X1 1600W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified
    2- OCZ Technology 256GB Vector Series SATA 6.0 GB
    2- XSPC Quad-Fan Radiator & 2- XSPC Dual-Fan Radiator
Tags for this Thread
