Results 1 to 3 of 3
    ROG Enthusiast Array zocker's Avatar
    Jul 2016
    72
    Intel Optane Memory Please Help for setup
    I cant get run the optane memory on my apex rampage vi.
    I installed it on the DIMM2 slot and in windows it was recognized as regular 27.1GB drive.
    I installed the optane memory tool and when i start it i got the message that
    are no compatible hard drives can be found.
    In bios settings i set AHCI to "intel rapid storage premium", but i read everywhere that i must
    set it to "intel rapid storage premium WITH OPTANE MEMORY".
    But this option is not available. I read also that there where an option "Remap to M.2" but
    i dont have this option to.
    I hope somebody can help, i am stuck!
    EDIT: OK i read that the x299 not supporting optane boost on secondary drives.
    Is there a workarround or a custom driver to get this work?
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,859
    What drives are you running other than the optane stick?
    This was meant as a buffer for a spinner to get the performance closer to SSD. Also it can only be set up to work with the drive the OS is installed on.
    Jul 2016
    72
    I have a Evo 960 256GB as boot drive and a 3TB hard drive.
    Yes, for the x299 boards only the boot drive can be boosted, but intel try to hide this.
    Intel speaks only from the benefits of the optane and x299 but they dont say directly that second drives are not compatible with x299.
    I have purchased one and then i noticed after trying the whole day that it does not work.
    No driver hacks or something to get second drive boost work on x299?
