Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    ROG Member Array bkgolden PC Specs
    bkgolden PC Specs
    MotherboardAsus - ROG Crosshair VII Hero WiFi
    ProcessorAMD - Ryzen 7 2700X
    Memory (part number)Corsair - Vengeance RGB Pro CMW16GX4M2C3200C16
    Graphics Card #1nVidia RTX 2080 FE
    MonitorAsus Rog Swift PG279q
    Storage #1Crucial MX500 1TB
    Storage #2SanDist Ultra II 960GB
    CPU CoolerCorsair 115i Pro
    CaseFractal Design Meshify C
    Power SupplyCorsair RMx 650
    Keyboard Corsair K70
    Mouse Corsair Dark Core RGB
    OS Windows 10 Home
    Accessory #1 Corsair LL 140 RGB Kit
    Accessory #2 Corsair Void Pro RGB
    Aug 2018
    14
    BIOS 1103 for CH7 wifi breaks iCue's control of my Corsair Vengeance Pro memory
    Like the title says, Corsair iCUE no longer detects my Corsair Vengeance RGB Pro (CMW16GX4M2C3200C16). The memory works great with tighter timings, just the RGB functionality is broken with the new BIOS.
    ROG Enthusiast Array
    Dec 2018
    34
    More Corsair problems.
    I'm having problems in iCUE too, but mine have been with my h150i cooler, which keeps connecting and disconnecting. I made a post about it in the official CH7 UEFI BIOS thread, but I'll post it here, too.
    Since I updated to the 1103 BIOS on my CHVII I've been having a lot of problems with my Corsair h150i AIO disconnecting and reconnecting.
    I'm running Corsair iCUE software to control fans and such, which could be the cause, or just part of, the problem.
    Specifically I'm having problems with this USB hub:
    * Device Name: Port_#0013.Hub_#0001
    * Device Mfg: (Standard USB Host Controller)
    * Driver Description: Unknown USB Device (Device Descriptor Request Failed)
    * Driver InfSection: BADDEVICE.Dev.NT
    * Instance ID: USB\VID_0000&PID_0002\6&20381000&0&13
    * Driver Version: 10.0.17763.1
    * Driver InfPath: usb.inf
    * Capabilities: Removable, SilentInstall, RawDeviceOK
    Disabling the USB hub stops the constant reconnecting.... but leaves me unable to control my h150i and connected fans with Corsair's iCUE software.
    I tried disabling USB selective suspend on all my USB hubs, and also went through to disable "Allow Windows to turn this off to save power" for the hubs and Corsair devices, but that didn't solve the problem.
    I don't know what other information you might need that could be helpful. If you let me know I'll try to get that info to you.
    Unless someone can suggest either troubleshooting or a way to get more debugging data, I'll probably be rolling my BIOS back this evening, so hit me up with advice if you've got any!
    ROG Enthusiast Array Zefram PC Specs
    Zefram PC Specs
    MotherboardAsus ROG Crosshair VII Hero
    ProcessorAMD Ryzen 9 3900X
    Memory (part number)G.Skill Trident Z RGB 32GB (4x8GB) F4-3600C18D-16GTZRX
    Graphics Card #1Asus ROG Strix 1080Ti OC Edition
    MonitorAsus PG279QZ 165Hz & VG248QE 144Hz
    Storage #1500GB Samsung 970 EVO
    Storage #24TB Western Digital
    CPU CoolerCustom Loop
    CaseFractal Design Define R6
    Power SupplyCorsair RM850x
    Keyboard Logitech G710+
    Mouse Logitech G502 Proteus Spectrum RGB
    Headset Sennheiser Gaming One
    Mouse Pad Razer Goliathus Control
    OS Windows 10 Professional
    Network RouterNetgear N600
    Accessory #1 Blue Yeti Blackout Microphone
    Zefram's Avatar
    Nov 2018
    33
    41
    I have the H150i also and haven't had any issues since the bios update. Maybe uninstall icue and reinstall again.
    bkgolden PC Specs
    OS Windows 10 Home
    Aug 2018
    14
    I used a NZXT internal USB hub to connect Corsair Commander Pro and my h115i Pro. Either the hub or the internal motherboard usb header is bad, because I would get similar iCUE reconnect issues. I ended up removing the hub and routing the Commander Pro USB cable outside the case and plugged it into an external port. No more reconnect issues with iCUE.
    Because of my memory issue, I ended up rolling back the BIOS to 1002.
    Dec 2018
    34
    Quote Originally Posted by bkgolden View Post
    For all it's worth (now that you've already rerouted all your cables) the USB re/connecting issue seems to be isolated to BIOS 1103 (at least in my case), so if you wanted to un-reroute all of your stuff you do have that option. 'course there's no saying whether the next BIOS will solve the problem or leave it in, since it seems like only a handful of us are having issues with this update...
    Is it normal that only a few of us are having problems while nobody else does? I thought our motherboards were all essentially identical, shouldn't this be an all or nothing sort of deal, either everybody has problems or no one does? The infrequency of problems makes me worry that my mobo might be borked.
    Zefram PC Specs
    Zefram's Avatar
    Nov 2018
    33
    41
    Yeah, I'm not sure. I only mentioned that I didn't have any problems with the same/similar hardware in hopes that it might help someone else narrow down their issue.
  7. #7
    ROG Member Array Hockster PC Specs
    Hockster PC Specs
    MotherboardAsus Maximus XI Formula
    Processori9 9900K
    Memory (part number)Corsair Vengeance Pro RGB 3200
    Graphics Card #1Asus RTX2080 Ti
    Sound CardOnboard
    MonitorAcer Predator (3440X1440)
    Storage #1Samsung 970 Evo NVMe
    Storage #2Samsung 860 Evo
    CPU CoolerCorsair H150i
    CaseCorsair 500D SE RGB
    Power SupplyCorsair HX1000i
    Keyboard Logitech G105
    Mouse Logitech G500
    Mouse Pad XTRAC Ripper
    Headset/Speakers Logitech 5.1
    OS Windows 10 Pro
    Hockster's Avatar
    Dec 2018
    11
    I've got the same issue with the 1103 BIOS and my Vengeance Pro memory. Thankfully I'm not suffering the disconnecting USB issues.
  8. #8
    Jul 2018
    20
    52
    Same here
  9. #9
    New ROGer Array
    Dec 2018
    1
    Same here. :/
  10. #10
    Zefram PC Specs
    Zefram's Avatar
    Nov 2018
    33
    41
    they just released an iCue update. Perhaps that will help/fix things.
