Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    ROG Guru: Orange Belt Array
    Jan 2015
    260
    Will I have RAM clearance for NH-D15? (Fractal R5)
    Hi. Question. Case Fractal Design R5. Ram
    https://gskill.com/en/product/f4-3000c15d-32gvr cooler - Noctua NH-D15
    Will i fit all ?
    i mean clearance
    RAM is 42mm tall
    Mobo: Asus Prime 390-A
    Or just use 1 fan instead of 2,on noctua? Doesnt matter on temps ? But according to pcpartpicker all should be fine, cause i see many pcbuilds with the same products.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Steelseries Prime+
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,442
    Hi Ipiotrowski211
    You can raise the 2nd fan for ram that is taller than 32mm, your case supports cpu coolers up to 180mm in height so it shouldn't be a problem.
    Jan 2015
    260
    But i saw builds when peoples dont raise that second fan. Hmm?
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,442
    They must be using low profile ram.
    ROG Guru: Green Belt Array geneo PC Specs
    geneo PC Specs
    MotherboardMaximus XII Hero
    Processori9-10900k 5.1Ghz AVX0 @ 1.28v core, delid
    Memory (part number)64 GB G.Skill TridentZ RGB 3200/CL14 @ 3600 CL16
    Graphics Card #1Asus ROG Strix 2070 Super A8G
    MonitorEIZO Coloredge CG2730 and Viewsonic QHD displays
    Storage #1Samsung 512 GB 960 Pro
    Storage #21TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black and 6TB IronWolf Pro HDD
    CPU CoolerEK-AIO 360 D-RGB
    CaseFractal Design Meshify 2 dark tint
    Power Supply750W Seasonic Prime Ultra Titanium
    Keyboard CM Quickfire Rapid TKL
    Mouse Logitech G305
    Headset Bose QC15
    Headset/Speakers Vanatoo T1, Klipsch R-12SWi Sub, Bose QC-15
    OS Windows 10 Pro X64
    Network RouterLinksys EA7300
    Accessory #1 Logitech c920e webcam
    geneo's Avatar
    Feb 2014
    40
    533
    Those are raised.
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,442
    Ripjaws V will work but because it's taller than 32mm you'll have to raise the fan some, those guys in those builds with Ripjaws V had to raise the 2nd fan too.
    To avoid any issues with clearance, Corsair Vengeance LPX is a good choice with a height of 31mm.
  8. #8
    Jan 2015
    260
    my pc technician dude will do this, are you sure bro everything will be fine? He is experienced.
    Or just use simply 1 fan instead of 2 of noctua?:]
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,442
    Yes, I'd use both fans and raise the 2nd fan a little.
  10. #10
    Jan 2015
    260
    feeling anxiety always before plugging new parts pc damn but ok i think i will survive.
    Maybe because all is too much expensive?
    DOnt know what is f wrong with me. I should be happy not scared. Of course the Cure will be not console. Still pc yeah but what cure?
    I am fine overall. Eh damn. Must go running again,sport.
    I mean yeah just nervous. To not stress this dude i just go out from home when he will be completing all : D
