Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    ROG Junior Member Array
    Dec 2018
    1
    Question Maximus XI Extreme PCH heatsink screw stuck / RMA?
    Hi everyone
    I recently received my brandnew M11E motherboard.
    Unfortunately one of the PCH heatsink screws (3 in total) sits very tight and can't be loosened.
    So far every attempt to loosen the screw failed. To make matters worse the screw head is stripped.
    It is one of those micro flathead screws. Very small and fragile. The other two screws were secured by Loctite. Maybe too much?
    There are two M2 NVMe ports below the PCH heatsink I want to access.
    I uploaded some pictures in order to show you
    https://www.dropbox.com/sh/i167973um...iTAN8vpda?dl=0
    Any idea? RMA?
    It's so frustrating.
    Best regards
    Robert
    ROG Member Array Endo2412 PC Specs
    Endo2412 PC Specs
    MotherboardAsus ROG Maximus XI Extreme
    ProcessorIntel Core I9 9900K
    Memory (part number)Corsair Vengeance LPX CMK32GX4M4B3200C16
    Graphics Card #1Asus Strix GTX 1080 TI OC
    Graphics Card #2Asus Strix GTX 1080 TI OC
    MonitorAcer HN274H
    Storage #1Samsung NVMe SSD 960 PRO 512GB
    Storage #22x Samsung SSD 840 Pro 256 GB, 1x Samsung SSD 850 EVO 250GB
    CPU CoolerCustom watercooling loop
    CaseCorsair 900D
    Power SupplyCorsair AX1200i
    Keyboard Corsair Vengeance K70
    Mouse Logitech G9
    Headset Corsair Void
    Headset/Speakers Logitech X-540 5.1 Speaker System
    OS Win 10 Pro
    Mar 2013
    12
    I had the same problem. totally stripped the head. To fix it i bought a grabit screw remover and got it out (https://www.ebay.com/bhp/grabit-extractor)
    good luck
    Kevin
    ROG Guru: Yellow Belt Array
    Nov 2015
    130
    Mine didn't have loctite on them however, the thermal pad sticky wasn't on correctly and was actually sticking to some components before I even peeled it off
    ROG Guru: White Belt Array MorePower PC Specs
    MorePower PC Specs
    MotherboardAsus Maximus XI Extreme
    ProcessorIntel i9 9900K
    Memory (part number)G.Skill Trident Z RGB 32GB
    Graphics Card #1ASUS Strix 2080 Ti OC
    MonitorLG UltraGear 34GK950G
    Storage #1Samsung 970 PRO NVMe M.2
    Storage #2Samsung 860 PRO SSD x 2
    CPU CoolerASUS ROG Ryuo 240
    CasePhanteks Evolv X
    Power SupplySeasonic Prime Ultra Titanium 850W
    Keyboard Corsair K70 RGB MK.2 Low Profile
    Mouse Corsair M65 RGB ELITE
    Headset/Speakers Kanto YU4 + Sub8
    OS Windows 10 Pro
    Oct 2012
    76
    At this point it would be best to get a screw extractor kit. Asus should of used flat-head hex screws. Using Philips on these high end boards is not smart. Why don't you use the Dimm.2 card?
    I have the same board and case as you. Does the RGB backplate on the board touch the case braces? I was going to remove the backplate but decided not to at this point. I have some flex near the end but maybe it won't hurt. How does yours look? Can you post pics?
    Thanks
    ROG Enthusiast Array
    Oct 2018
    37
    I am having the same issue. This is ridiculous. An expensive card that is the top of the series to have then a cheap screw .
    Did any of you was able to remove the screw?
    What Is the solution that works?
    ROG Guru: Green Belt Array Phillyflyer's Avatar
    Mar 2012
    30
    536
    Quote Originally Posted by marcolisi View Post
    No doubt the 3 screws are a snug fit....they can easily be removed...but requires some patience...a little heat (from hair dryer)...the correct size philips head screw driver and a bit of force from the top down on the screw head....if you rush to try and remove the screws..you will most definitely strip the head...it's not the screw that is so called "cheap" that is the issue...it more the process taken that will strip the screw head...
    I had no issues removing the screws with the process I have outlined .
    Asus ROG Maximus XI EXTREME
    Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
    XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
    Swiftech Drive II / Swiftech MCP35X Pump
    Enermax Platimax 1200 Watt Power Supply
    32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
    MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
    (5)Samsung 840 Pro 128 GB In Raid 0
    (2) WD 1TB Black Edition
    Corsair 900 D
  7. #7
    ROG Guru: Yellow Belt Array Guitarmageddon888 PC Specs
    MotherboardMaximus x code bios1704
    Memory (part number)8700k 5.1/4.9avx
    Graphics Card #1MSI 2080 gaming trio
    MonitorHP Omen 27"
    Storage #1Samsung 970 m.2
    Storage #2Samsung 860 evo
    CPU CoolerH150i
    CaseLian li pc011
    Power SupplyEvga supernova g3 850w
    Keyboard Corsair k70
    OS Windows 10
    Nov 2018
    12
    210
    Yes I ran into this on build day. I bet Asus supply chain is crowded with tons of otherwise perfect boards that people choose to RMA over it because there was no other option for them. Now those boards have to eat up repair depot time and
    money...for a $.01 screw . mine was stripped but I managed to get it out. Poor decision asus
  8. #8
    New ROGer Array
    Oct 2018
    1
    mine have the same problem, definitely the screws issue.
    it's not even a steel screw, that's why they are so easy to strip, and if you check more carefully, you can see some blue paint on the screws, that make it stuck more tighter.
    so the cheap screws and the stupid paint, that's why you cant loose it because the screw head cant even handle the torque.
    one more thing that make me angrier, I bring it back to the vendor, they call this is "human error" and not allow for change and no warranty.
    I was shocked, i mean, what!? You Asus put this trap on the board, and let the customers bear the responsibility? WHY?
    I was thinking may be I am that stupid to loose a screw until i found this thread, this is absolutely Asus problem. You just shirking all the responsibility to customer. Do you know how helpless i feel? I just want to remove that stupid heatsink and put my m.2 drive in....
  9. #9
    Mar 2012
    30
    536
    Quote Originally Posted by waterkwong View Post
    The blue substance you are referring to is called for "Locktite" and is used to to seal the gaps in the tread and prevent the screw from backing off...as I mentioned earlier...best way to handle removal of screw is by applying heat and applying top down pressure on the screw head....metal expands and substances soften with heat...The screw head can most certainly handle the torque if the correct size screwdriver is used with a heat application....I have personally encountered this issue with all 3 screws on first try ( and no doubt..they are snug) without stripping the screwheads...first instinct was to apply heat on 2nd try.....and easily removed screws...
    As for RMA refusal to to human error ???....Yes....I can understand Asus stance initially....but it is through the forum and posts of this nature that makes the manufacture aware and acknowledge that there is indeed an ongoing and frequent issue that is a manufactures defect and said damage was not a result of human error...that will have your RMA honoured.
    Corsair 900 D
  10. #10
    Oct 2018
    37
    Quote Originally Posted by Phillyflyer View Post
    It seems that others got into the same problem.
    Hence this is an issue. It should be something with no issue whatsoever .
    We are here to talk about it and there were other before having the same issue with other asus motherboard.
    Spending 600 dollars to get screwed by a screw doesn't feel right.
    I should bill asus 20 dollars for the extractor I have ordered for me now trying to remove the screw
