Results 1 to 3 of 3
    ROG Junior Member Array
    Mar 2016
    4
    Problems when waking up after sleep mode
    Hi guys
    Ive ran recently in to some problems with my asus g750.
    After performing a clean format, my sleep mode is really weird.*
    When waking up after sleep mode, i see the windows splash, login screen, homepage.
    But when i see the homepage, all my apps incl documents are shut down and needs to be restarted.*
    Chrome gives me an notification: recover your tabs, discord rebooting, some of my programs(office365) could not be located anymore.
    Ive tried:
    Another clean format(bootable usb)
    Hibernation settings off*
    Instructions on powermenu/ lid changes,...
    Restorehealth/ scan options in cmd
    Device manager adjustments for the intel management system*
    Disabled secure boot, enabled cmr
    Contacted asus live chat —> no solution
    I am kinda desperate, it started so suddenly after the clean format. Can anyone help me with this?
    Running windows 10 home on a samsung evo850.
    Bios upgraded to last version (has anyone good bios settings?)
    Thank you in advance******
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,126
    I suspect Windows power settings, simply because they seem to mess with everything, and I think they screw a lot of things up.
    I did a search and found THIS. You might give it a try if you haven't already done so.
    Davemon50
    Mar 2016
    4
    Unhappy
    Quote Originally Posted by davemon50 View Post
    unfortunately that doesnt work aswell...
    Hybride sleep is working though but I’d like sleep to work.*
Tags for this Thread
