Z390e VGA led after start
vgerg88
Hi
Ihave a brand new strix z390e mobo.
after a start (especially a cold start) i have no signal on screen in BIOS and POST phase i got only signal on the windows login screen and the white led on the mobo (means VGA problem) light. But i not detect any problem in windows and games. Just this led light.
When i restart the system or turn it off and on everything goes fine... i have BIOS, POST screen and no lighting led.
Somebody can help me what's the problem? its very anoying and confusing 😕
Checked all of the cabels and everything good.
My spec: asus strix z390e
intel core i7 8700k
corsair vengeance 2x16gb ddr4 3200mhz
strix geforce gtx 1080ti
coolermaster v1000 1000w psu
5 REPLIES 5
HiVizMan
Level 40
Is your bios set to defaults?
Save your bios settings if you have made ANY changes and reflash your bios. I wonder if there is a bit of a barrier for hardware communication during the initial handshake by the UEFI. A bios flash should resolve that if it is the case. Use the USB port at the back of the board and the bios flashback method please.
I aready refeshd the BIOS for the newest version yesterday night. and i didn't do any changes in the BIOS. the problem still but i think rarely.
I just need to ignore this? or it will be a greater problem?
Silent_Scone
Super Moderator
Are you using Display Port? Potentially a cable issue.
Yes i use display port but i don't think it cause the lighting led on the mobo.
I have the same "issue" everything works fine as far as I can tell, but that VGA LED is on 😄
