Asus GTX 1080 8G Turbo RGB/Aura Problem
Lukii
I bought this gem last year, and downloaded the original AURA whatever software is from official site and it totally froze my PC.
I only install drivers and I want to get rid of ASUS "flashlight" logo on it, cause this card has 1 cable input for power delivery not 2 as strix or other models.
I have installed Accellero IV on it, and now the LOGO light is still there active and I don't know how to turn it off.
GPU TWEAK LITERALLY FROZE MY PC EVERYTIME, so I installed Afterburner instead... I don't know if this is fixed or not. I just want this logo OFF without any downloadble programs that have to keep it off. Is it possible to do this???
The downloaded software from official site here(doesn't work, it freezes my PC):
https://www.asus.com/us/Graphics-Cards/TURBO-GTX1080-8G/HelpDesk_Download/
OS Win10 PRO Original 64bit
My PC specs are:
CPU: i7 4770k@4.5ghz
FAN: CoolerMaster Nepton 120 XL
Case: Silencio 652S
MBO: ASUS MAXIMUS VII RANGER
RAM:24GB RAM
@CL9 2x8GB Mushkin Redline 2133Mhz+,1x8 GB Mushkin Blackline 2133Mhz
HD: 240GB INTEL SSD,+120GB Kingston SDD+ 1TB WD Blue
GPU: ASUS GTX1080 Turbo + Arctic Accelero Xtreme IV
PSU: CS750M 80+ GOLD
Monitor: ASUS VG248QE
SirWaWa
try this, I hope it works since it works perfect on the strix cards
download asua aura for GPU only! once you set it, the setting should remember even after power off, you don't need to run this at startup as it likes do so
I used this both on a 1080 and 1080ti and it remembers the setting with power off and run at startup not required, infact you can uninstall it once your satisfied
https://www.asus.com/ca-en/Graphics-Cards/ROG-STRIX-GTX1080-O8G-GAMING/HelpDesk_Download/
Version 0.0.5.5 2017/09/27 11.08 MBytes
ASUS AURA
Enhance system compatibility
there's a new version but i had no problems running the above
Version 0.0.6.1 2018/09/20 11.28 MBytes
AURA_RGBLightingControl_for_Graphic_card_XG-STATION
AURA RGB Lighting Control for Graphics card & XG-STATION ver0.0.6.1 now support GeForce RTX20 series
ASUS AURA
ASUS AURA
ASUS AURA
Well I got this message, and lights are still on...
https://i.imgur.com/9yjqhfS.png
