12-06-2018 09:30 AM - last edited on 03-06-2024 07:34 PM by ROGBot
12-06-2018 09:43 AM
12-06-2018 10:36 AM
12-06-2018 10:47 AM
12-06-2018 11:07 AM
Guitarmageddon888 wrote:
Hello all. 8700k and Maximus x code here. I'm starting to fiddle with an Oc but I do not want to do it the manual way leaving voltage high at idle. Does anyone have experience using the adaptive mode? Here is my assumption I need some guidance on. I basically can just switch to "adaptive" then select my new voltage for the turbo multi. Keep svid best case still probably? Then play with llc as needed? Sounds pretty similar to manual mode in practice. Offset mode was harder to understand I don't quite grasp offset versus adaptive. Adaptive basically doesn't touch the stock down clock voltage/speed is my assumption?
12-06-2018 11:49 AM
12-06-2018 01:34 PM
12-07-2018 03:59 AM
12-07-2018 07:03 AM
