Water-cooled ASUS Maximus XI Extreme + Evolv X
Philizard
My first Water-cooled Build.
My previous PC must have been 10 years old, Intel i7 920. Thought I had go nuts at least once in my life.
It's still a bit of a work in progress.
I was inspired by the water cooled Evolv X at Computex. However I wanted it to be different with the vertical GPU and tubing. I had to make a bracket to move the Res forward so that it would fit just right, although it blends in quite well. Also there is a small metal block under the GPU bracket to hold the GPU up at the increased height.
Still to do:
- Tubing will be redone, as it is far from perfect.
- I will either get a new PSU or at least cover the label.
- Likely a Monoblock if bitpower or Ek release one that appeals to me (Might grab a 9900k, as i've got another use for the 8700k)
- Figure out if the existing vertical slots can be used for something... Considered an intel 905p, though that seems way overkill (And expensive)
Case: Phanteks Evolv X
CPU: Intel Core i7 8700K
Motherboard: ASUS MAXIMUS XI Extreme
Graphics Card: Nvidia RTX 2080 Ti
OS Storage: Samsung 970 PRO 512GB M.2 NVMe SSD
Games Storage: 2 x Samsung 970 EVO 1TB M.2 NVMe SSD
PSU: Corsair RM1000
Noctua 140mm NF-A14 PWM Chromax Black Swap Edition 1500RPM Fan x 6
Phanteks Glacier C350i CPU Water Block Black
Phanteks GB2080FE RTX 2080 Ti FE GPU DRGB Waterblock Chrome
Phanteks Glacier R220 RGB Reservoir
Phanteks 16mm Chrome Hardtube Fittings
EK CoolStream CE 420 Dual Radiator
EK CoolStream SE 280 Dual Radiator
EK HD PETG Tubing
Phanteks Halos Lux 140mm Digital RGB
CableMod WideBeam Magnetic LED Strip UV 30cm x 3
Custom Cables from CableMod
77527
77528
Let me know what you think or any ideas for improvement!
Thank you,
Phil
Edit: Added some better photos
xr1200
Looks great! your bends are nice.
jimsond
You did a nice job!! 🙂
Corsair D900 Custon water cooled!
ASUS RAMPAGE V EXTREMIMG
i7-5930K Haswell-E 6-Core
G.SKILL Ripjaws 4 series 16GB (4 x 4GB) 288-Pin DDR4 SDRAM DDR4 3000
2- EVGA GeForce GTX 980 TI Hydro Copper Signature
EVGA 120-G2-1600-X1 1600W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified
2- Swiftech MCP655 pumps & Bitspower BP-2D5TOPP-BK Dual D5 Mod Top
2- OCZ Technology 256GB Vector Series SATA 6.0 GB
2- XSPC Quad-Fan Radiator & 2- XSPC Dual-Fan Radiator
panzlock
Level 12
With the lighting on, the inside of your PC makes me think of this:
With the lighting off, the inside of your PC makes me think of this:
Clean, solid build. Looks serene with the blue lighting, but very mechanical and manly with no lighting.
I want to see your sandwich assembly next. Don't let me down.
I'd like to deploy my troops in her country.
