Problem with different temps CPU between AI suite3, core temp and hwmonitor
Koutport
Hello,
I have different temps on my cpu .
What temperature is the right;
I reinstall the Ai3 ,but the problem remain the same .Any ideas pls.
Μobo:ROG STRIX Z790-F GAMING WIFI-CPU:Intel Core i9-14900K-Cooler:EKW-EK-KIT RGB 360-RAM:G.SKILL Trident Z5 DDR5-6400 CL32 64GB(4 x 16 GB)-GPU:ASUS GeForce® ASUS ROG STRIX GAMING RTX-3080Ti-#43; EKW-EK-KIT 480 RGB -PSU:Corsair HX1200i:HDD:Samsung M2 980 PRO with heatsink 2TB+Samsung 990 PRO 2 TB RAID-0 +Asus RAIDR Express 240GB- Case:Thermaltake View 91 Tempered Glass RGB Editionx
Arne_Saknussemm
Level 40
If you run multiple programs at the same time the readings can be off. Always best to run only one.
I think AISuite is "package" temp not core temps. It's the core temps that are important. They will vary for each core...sometimes up to 10 degrees..though we always hope for a lower spread...
Thank you for youre quick reply Arne.
