Results 1 to 9 of 9
    ROG Enthusiast Array Top3koms PC Specs
    Top3koms PC Specs
    MotherboardAsus Rampage VI Apex
    ProcessorIntel 7820X
    Memory (part number)G.Skill Ripjaws 4 2800
    Graphics Card #1Asus ROG Strix 1080Ti
    Sound CardCreative Soundblaster Z
    MonitorAsus Rog Swift PG278Q
    Storage #1Samsung 850 Pro 128Gb
    Storage #2Samsung 850 Pro 500Gb
    CPU CoolerCorsair H115i
    CaseCoolermaster Cosmos II
    Power SupplySeasonic Platinum - 1200W
    Keyboard Corsair K95 Platinum
    Mouse Logitech G403
    OS Windows 10 64bit
    Top3koms's Avatar
    Sep 2014
    47
    Question CPU C-states causing my monitor to power off when computer is idle
    I recently built a new computer with a 9900K on a Maximus XI Formula.I have been having a tough time getting the monitor (PG278Q) to not power off when the computer is idle when using CPU c-states.The only way I can seem to get the monitor to not power itself off is by disabling CPU C-states and then I am stuck at 4.7 Ghz and it will not boost to 5.The monitor is connected to a Strix 1080ti video card and I have 32Gb of gskill 3200 ram.I am hoping to be able to set c-states to enabled so the CPU can save power when not in use and boost to 5 Ghz when needed.Has anyone had a similar issue or may know what is causing this issue?
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,452
    Have you set display not to power off in power plan?
    Top3koms PC Specs
    Mouse Logitech G403
    OS Windows 10 64bit
    Top3koms's Avatar
    Sep 2014
    47
    Quote Originally Posted by Arne Saknussemm View Post
    Yes I have to set the power plan to High performance and the Display to turn off after two hours of inactivity.
    I have taken out and reseated the cpu.I have replaced the original 1200W Seasonic Power supply with an EVGA 1000W one.I unplugged all extra SSD's except the Samsung 970 EVO NVMe drive I have the OS on.I tried without my sound card in as well.All ending with the same result.
    Apr 2012
    481
    13,452
    And in the monitor menu itself there is no sleep setting on?
    ROG Member Array Numbie PC Specs
    Numbie PC Specs
    MotherboardASUS Strix Z370-F
    ProcessorIntel Core i7-8700K @ 5 GHz 1,3 V
    Memory (part number)2x8 GB @ 3200MHz CL16
    Graphics Card #1ASUS Strix 1080 Ti
    Sound CardAudiotrak Prodigy Cube Black Edition
    MonitorASUS ROG PG279Q
    Storage #1Samsung 970 Pro 512 GB
    CPU CoolerNZXT Kraken X62
    CaseNZXT S340 Black
    Power SupplyCorsair RM650x
    Keyboard Cougar Vantar
    Mouse ASUS Gladius II Origin
    Mouse Pad Steelseries Qck
    Headset/Speakers AKG K240 MKII
    OS Windows 10 Pro
    Apr 2017
    8
    To get voltage and frequency drop use CPU and package in C1 to C3 state, not higher. Maybe this will fix your issue.
    Top3koms PC Specs
    Mouse Logitech G403
    OS Windows 10 64bit
    Top3koms's Avatar
    Sep 2014
    47
    No there is no setting in the monitors menu for sleep
  7. #7
    Top3koms PC Specs
    Mouse Logitech G403
    OS Windows 10 64bit
    Top3koms's Avatar
    Sep 2014
    47
    Quote Originally Posted by Numbie View Post
    I tried enabling c-states with disabling all the individual C4 ,C5,C6 states etc but the issue still eventually (sometimes before I even log into Windows 10 X64) occurs once I have switched to the balanced windows power plan.
    Thank you both for attempting to help me with this issue.
  8. #8
    Apr 2012
    481
    13,452
    You can edit the power plans individually...
  9. #9
    Top3koms PC Specs
    Mouse Logitech G403
    OS Windows 10 64bit
    Top3koms's Avatar
    Sep 2014
    47
    I have tried a bunch of different settings for the balanced windows power plan and each time I have had the same issue.
