Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    ROG Member Array
    May 2016
    21
    Asus G752VT RAID 0 - problem with sound
    I installed windows 10 on 2x ssd 960 evo with RAID 0. I have problem with sound during copying files or using apllications. The sound is interrupted.
    When I install windows 10 on one ssd without raid the sound is ok. How to solve this problem?
    ROG Member Array
    May 2016
    21
    Did someone set the raid 0?
    ROG Guru: Orange Belt Array
    Nov 2012
    55
    399
    You have a problem with the installation of Windows 10 in Raid 0. Are you installing Windows 10 natively or copying from previous single ssd installation?
    This problematic Windows 10 installation is the cause of all your other problems (multiple posts).
    Good Luck
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    ROG Member Array
    May 2016
    21
    I made a clean installation of windows. I have loaded RAID drivers at the beginning of the installation.
    Nov 2012
    55
    399
    Are you using the RAID drivers found in your eSupport folder?
  7. #7
    Nov 2012
    55
    399
    The version of IRST driver your laptop model should be using is found in your eSupport folder (Software/Rapid Storage/14.6.3.1032/3135/PNPINST64.exe).
  8. #8
    ROG Member Array
    May 2016
    21
    I have only 14.6.0.1029 version in my eSupport folder.
  9. #9
    Nov 2012
    55
    399
    That is an eSupport folder you got on this forum three years ago because you deleted your original?
    You know, I don't even know if that will work. The copy of the eSupport folder (Driver DVD) I see is version 4.0 dated 3.3.2017.
    Before you wipe out your hard drive, make a copy of your eSupport folder. Then if you are going to create a Raid, you have a copy of the driver built to properly support your Raid chip on your motherboard. Then once you have Windows installed you can use the ASUS Installation Wizard (AsInWiz.exe) to install all the original ASUS drivers and programs that were developed for your laptop.
  10. #10
    ROG Member Array
    May 2016
    21
    ok, thanks, I will try it.
Tags for this Thread
