Hello,
I am having trouble reaching 4 Ghz on an i5 8400.
Setup:
System board: ASUS TUF B360-Plus Gaming
Ram: 2x 8Gb 2133mhz DDR4
Gammaxx 300 CPU Coller
Intel i5 8400 tray
620W Seasonic
Latest Bios.
Win 10 x64.
According to Intel's specifications, the turbo table of this cpu should be the following:
4,000 MHz (1 core),
3,900 MHz (2 cores),
3,900 MHz (3 cores),
3,900 MHz (4 cores),
3,800 MHz (5 cores),
3,800 MHz (6 cores)
I was having trouble to get the cores from 3.8Ghz to 3.9Ghz, and C state being disabled was causing it, but still no 4Ghz. Uncore multiplier does not go over x36 in multi core mode.
Disabled 5 cores from BIOS, here's what I got:
1x sits at 4000Mhz, x40 multiplier.
Uncore is at 3700Mhz, x37 multiplier.
ACPI timer is at 3580mhz.
Windows is in High Performance.
C states:
No difference between Auto and Enabled.
Enabled it has C8 and C9 disabled, but enabling these 2 makes no difference.
In the bios it states the target for turbo is 4000mhz, and 3700mhz for cache.
Tried all possible combinations (but maybe I missed something).
Tried clearing the BIOS.
CPU power enhancement does not seem to have any effect (2 settings Auto/Disabled).
Intel SpeedStep and SpeedShift have no effect.
Tried setting in BIOS from Auto to Performance. This maxed out some settings, but disabled C states.
iGPU is disabled.
BCLK in BIOS it says it's 100mhz. In windows it stays between 99.7 and 99.8mhz.
Went into bios and set the first core multiplier at x40, and x28 for the rest. In windows all the cores stayed at x28 regardless if a benchmark was running or not.
Tried setting 1 core at x40, then all 6 cores at x40 from BIOS.
Maxing out the settings in AI suite 3 did not make any difference.
Tested 1 core only with CPUZ utility, Prime 95, OCCT,
https://imgur.com/a/iddh6tVIn the XTU comparisons page on the website (after benchmark) , besides the others having z370 boards, the Turbo Boost Power Max was increased.
Should I attempt to raise it as well?
There is another thread on a ASRock board with the same issue, and apparently it was fixed with possibly a modified bios:
http://forum.asrock.com/forum_posts.asp?TID=10308&title=z390-phantom-gaming-i5-8400-turbo-boost
