Results 1 to 5 of 5
    ROG Junior Member Array
    Dec 2018
    2
    asus zephyrus touchpad issues
    I just purchase an Asus Zephyrus laptop and although the touchpad is not the greatest, it's very problematic in games. I have the latest drivers all around as updated whats on the website. Shows the Asus precision touchpad drivers 11.0.0.25. When I'm in games, and try to move around and turn at the same time, the touchpad doesn't work. So I'm holding down the "W" key to move forward, and trying to look left and right with the touchpad. It fails to turn until I stop moving. Plus a lot of times when I click the mouse buttons it doesn't work. The closest I got to it working is to disable the tap click, double tap, two and three and four finger gestures. Basically neuter the device. Plus set the sensitivity all the way to max. Then it's OK but still has times it fails to respond. Any thoughts on how to resolve this? I've tried some of the suggestions for different drivers but they don't seem to work. Should be noted in the device manager it shows a HID Mouse and in the Human Interface Devices it shows the Asus Precision Touchpad. I do not have any other mice installed by the way. Thoughts?
    Thanks.
    Steve
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    397
    8,401
    Quote Originally Posted by syarbrou View Post
    What you are describing is a feature to keep the touchpad from accidentally registering if you brush it with your palm while typing. This is sometimes referred to as palm rejection. If it's available you would have to change/disable the setting in the touchpad configuration.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Dec 2018
    2
    Yeah there is a setting called sensitivity. I think that's what would correlate to what you are saying but doesn't seem to change max or min. No off option. I oddly switched from the precision touchpad drivers to the built in Windows HID-compliant touch pad drivers and it's "better". I still have times that I put my finger on the touchpad and try and move and nothing. Then lift up my finger and put it back down again and it responds. Not great when you are playing a game and get killed because your action didn't happen.
    Steve
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    397
    8,401
    Steve
    Well, what I'm referring to is a feature on some systems where the touchpad is effectively disabled while the keyboard is in use. But upon rereading your post it sounds like this is an intermittent issue which wouldn't correspond to an on/off setting.
    It could just be general touchpad flakiness. In general I have found touchpads to be frustrating for gaming. I'll use the touchpad for work but I carry a mouse for gaming. As far as I know nobody really makes a "gaming" touchpad for laptops. Touchpad designs are all extremely similar so all the laptop manufacturers are buying from the same pool of touchpad producers.
    ROG Enthusiast Array
    Nov 2018
    46
    Steve
    May I ask how you did the switch? I have the exact same issue but I don't use the touchpad for gaming - I always go with a mouse. Touchpads have always been bad for gaming to be honest.
Tags for this Thread
