12-10-2018 06:23 PM - last edited 3 weeks ago by ROGBot
12-15-2018 10:05 AM
TimmyP7 wrote:
I have a case. Mattrexx Deepcool 55. It has a hardware button (Individual Colors, Fade Cycle, Flash Cycle, Blend Cycle) and controller on the case with extra connectors to expand. None of this is controlled by any software. I have it looking good.
Also have a Logitech G510 RGB programmable keyboard (LGS scripting LUA), and I am looking to sync this. But you know there is only one way if its even possible:
Does anyone know the formula for ASUS Aurasync hardware RGB cycles? Like fade cycles work at a constant time, I wanna match this up.
I am so close, but its just by eye. I cannot "reverse engineer" the color cycle but it is SO CLOSE. I KNOW it uses a standard deviant of time somehow. I can just tell.
Does anyone know this? It would be time-oriented. (Like the total time of every color cycled, I could "port" this I am right there if I knew how it related to exact seconds, or I could derive this from the code that drives Aurasync)
If not I understand. tldr I am triying to sync up an RGB software keyboard with a hardware only case.
