Results 1 to 6 of 6
    ROG Guru: Orange Belt Array rjbarker PC Specs
    rjbarker PC Specs
    MotherboardMaximus XI Extreme (BIOS 0605)
    Processor9900K @ 5.1 Ghz w EK Velocity
    Memory (part number)32 GB -Dominator Platinum 3200 Mhz CAS 16
    Graphics Card #1Evga 1080Ti SC Black Edition w EK FC Blocks
    Graphics Card #2Evga 1080Ti SC Black Edition w EK FC Blocks
    Sound CardOnboard Realtek
    MonitorDell Alienware 34" Ultra wide 120Hz Gsync
    Storage #1Samsung 970 Pro 512G M.2 NNMe
    Storage #2Samsung 860 Pro 512G & 256G
    CPU CoolerEK Supremacy Copper w Nickel Plating
    CaseCorsair 900D
    Power SupplyCorsair AX 1600i
    OS W10 HP x64
    Accessory #1 480 * 360 * 240 XSPC Radiators (15 Fans) w 4 Channel 200W Fan Controller
    Accessory #2 XSPC Photon Rez / Vario Pump combo
    Accessory #3 Fesser Flex Tubing - Bits Power Fittings & EK SLi Terminal
    rjbarker's Avatar
    May 2013
    16
    291
    Maximus XI Extreme - Sealed Box?
    Recieved my Maximus XI - E from online purchase "Memory Express" here in Canada.
    Couple of questions:
    - Is the actual product box normally come with tamper proof seals (mine had no seals on the box).
    - Should the board come with a S/N Sticker on the Board itself ? (Product, Model and S/N sticker was only present on the box).
    - There are a couple of stickers on the Board itself, but the Code Numbers / Letters don't match any of the sticker numbers (Model, S/N or product) on the box.
    Pardon my ignorance, but the last Board I purchased was almost 5 yrs ago (Rampage IV Extreme) and that box came sealed in plastic from the the supplier.
    The board looks fine and Im waiting for one more part prior to assembling on my bench for first boot.....
    Thanks
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    ASUS does not seal there packaging so no issue there.
    I believe there should be a S/N on the board, maybe it is hidden under a heatsink or I/O cover where it cannot be seen, I am not sure
    ROG Enthusiast Array
    Sep 2013
    36
    48
    Not sure if it's the same on the Extreme, but on my Formula, the S/N sticker (which matches the S/N on the box) is on the bottom of the motherboard, near the CPU backplate.
    ROG Guru: Yellow Belt Array Guitarmageddon888 PC Specs
    MotherboardMaximus x code bios1704
    Memory (part number)8700k 5.1/4.9avx
    Graphics Card #1MSI 2080 gaming trio
    MonitorHP Omen 27"
    Storage #1Samsung 970 m.2
    Storage #2Samsung 860 evo
    CPU CoolerH150i
    CaseLian li pc011
    Power SupplyEvga supernova g3 850w
    Keyboard Corsair k70
    OS Windows 10
    Nov 2018
    12
    209
    Yep wondered the same on my code. I don't like that
    rjbarker PC Specs
    CaseCorsair 900D
    OS W10 HP x64
    rjbarker's Avatar
    May 2013
    16
    291
    I
    ll have another look but I see no S/N sticker that matches the box anywhere on this Board..
    ROG Guru: Orange Belt Array geneo PC Specs
    geneo PC Specs
    MotherboardMaximus XII Hero
    ProcessorIntel 1070k @ 5.1Ghz
    Memory (part number)64 GB G.Skill TridentZ RGB 3200/CL14 @ 3600
    Graphics Card #1Asus ROG Strix 2070 Super A8G
    MonitorEIZO Coloredge CG2730 and Viewsonic QHD displays
    Storage #1Samsung 512 GB 960 Pro
    Storage #21TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black HDD
    CPU CoolerNoctua NH-D15 Chromax
    CaseFractal Design R4 w/ tempered glass
    Power Supply750W Seasonic Prime Ultra Titanium
    Keyboard CM Quickfire Rapid TKL
    Mouse Logitech G305
    Headset Bose
    Headset/Speakers Vanatoo T1, ML Dynamo 300
    OS Windows 10 Pro X64
    geneo's Avatar
    Feb 2014
    37
    429
    Quote Originally Posted by Guitarmageddon888 View Post
    Yeah, I expect they are doing it for a reason, and you can easily speculate on what that is.
