Results 1 to 9 of 9
    ROG Member Array
    Apr 2013
    5
    ROG Ryujin 360 - Internal Fan Question - Urgent
    Hello @all
    i have done the setup with the ROG Ryujin 360.
    Using different Fans insteed of the Noctuna Industrial Fans. ( Thermaltek Riing RGB Plus Premium )
    My problem is if i dont use the attached Fan adapter from the AOI Pump i can not make the internal Mini FAN Silent !
    Its allway on 100% and very loud
    What i figured out is first time i have used it with the Noctuna Fans attached to the FAN adapter from the AIO Pump. I could see the FAN curves in FAN EXPERT.
    It is possible if i dont use this 3 pin adapter for the fans direct from the pump i can not adjust the speed of this mini FAN inside the AIO Pump ?
    Its penetrating me
    Greetings
    Devjam
    ROG Member Array
    Apr 2013
    5
    Yesterday i found the solution i guess
    If you setup the AIO first time with attached fans you can adjust the internal fan the pump and the external fans.
    I think there is a safe function what keeps the setting saved.
    If you AIO is not attache to the powersuply it will lose the saved settings after a certaine time.
    So i have attached 1 fan to adjust the internal fan => pluged out the external Fan => internal Fan is still under controll with the saved settings.
    What i need to check or test is unplug the powersuply and see if the settings get lost.
    Can anyone from the ROG Team confirm this or explain how this is working ?
    Greetings
    Devjam
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,439
    Quote Originally Posted by Devjam View Post
    Greetings
    Devjam
    I don't know if anyone here will be able to give you a definitive answer. So far I haven't seen a lot of detail on this product. But your experience does seem consistent with the youtuber Jayztwocents. He had a broken fan plug and used separate fans for his testing. He found the internal fan to be uncontrollable as well.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    79
    914
    I have the Ryujin 360 and can currently control all the fans. I will disconnect the Noctua fans and see if I lose control of the pump house fan. I will report back.
    Question: Do you have the USB cable connected to the motherboard?
    Also, why not connect the new fans you have to the AIO cooler for control through Fan Expert?
    ROG Member Array
    Apr 2013
    5
    Hello Thanks for your Feedbacks
    I know this product is new. Thats why i trying to share the expirience.
    1. I have attached Thermalthek Riing Fans ( 9x pices )
    2. This 9 Fans are connected over the Thermalthek RGB / PWM controller ( you have to buy is additional 25$ )
    3. Connect the Thermalthek controller to the Fan Controls on your motherboard ( PWM 3x Fan => 1 Adapter to plug )
    4. Organize the software setup all what you need and want. ( during this process i have attached 1x Fan direct to the AIO pump to make the adjustment )
    5. Plug out the Fan use the other 9 Fans over AI Suit incl. the Fan inside the AOI.
    Hope this helps if not please let me know )
    Greetings
    Devjam
    ROG Member Array
    Feb 2019
    Hello @all
    Its penetrating me
    Greetings
    Devjam
    That internal Mini FAN is humming irritatingly. I wish I went another route, like air-cooler. I just want to deactivate that internal Mini FAN. I have read your posts but I can't figure out yet, how to deactivate that noisy internal Mini FAN. Ouch!
  7. #7
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    79
    914
    Quote Originally Posted by jolol View Post
    *Have you loaded AI Suite? * If so, you will have a separate fan curve to control the pumphouse fan. *The other fan curve will be for all of the *radiator fans together
  8. #8
    ROG Member Array
    Feb 2019
    Yes, I have installed AI Suite, and thinker with it everyday. I'll try your suggestion. Thanks!
  9. #9
    ROG Guru: Orange Belt Array 1mluer PC Specs
    1mluer PC Specs
    MotherboardMaximus IX Apex & Maximus XI Apex's
    ProcessorI7-7700k & I9-9900k
    Memory (part number)Gskill Trident Z RGB 4266 & 3200 DC
    Graphics Card #1MSI Sea Hawk 1080 & ROG Matrix 2080 ti
    Sound Cardbuilt in for both
    MonitorSamsung 27inch & ASUS Swift PG348Q
    Storage #1Samsung 960 Pro & Samsung 970 Pro
    CPU CoolerRyuo 240 & Ryujin 360
    CaseInWin 909 Black & InWin 909 Silver
    Power SupplySeasonic 1000w Titanium & ROG Thor 1200p
    Keyboard Corsair K95 & ASUS ROG Claymore
    Mouse Logitech G902 & ASUS Gladius II Origin
    Mouse Pad Corsair MM800 & ASUS ROG Baltheus
    Headset/Speakers Bose Computer Set with Sub
    OS Windows 10 Pro all around
    Network RouterLinksys EA 9500
    Accessory #1 Corsair LL / Commander Pro & TT Riing Plus
    Accessory #2 Blue Microphone
    Feb 2017
    33
    330
    Hello @all
    Its penetrating me
    Greetings
    Devjam
    I plan on adding the Riing Plus Premium fans too but they will go into a push pull configuration with the Noctua fans that come with the cooler. the noctua will be pulling air out of the case through the radiator and the Riing Plus fans will be in the prominent display position pushing air through the radiator.
    I get a double benefit - Even Better cooling and awesome RGB.
    the Riing plus fans will be controlled via Ring Plus RGB software with similar fan curve as set for the noctua's in AI Suite..
    Win / Win in my book. Just install the standard fans for the 360 like normal just make them push or pull depending on how you need to use them.
    Also issue solved with run away internal fan
    Inwin 909 Black RGB build
    i7-7700k
    ROG Maximus IX Apex
    1080 Sea Hawk
    InWin 909 Silver RGB build
    i9-9900k
    ROG Maximus XI Apex
    ROG Matrix 2080 ti
    Gskill TridentZ RGB DC 3200 64g
    Everything overclocked and love it.
    ROG Awesomeness !!!!
