MAXIMUS XI EXTREME - cannot select m2-disks in IRST-Create RAID Volume
DOOMy
first, my Hardware:
M-XI-E with 0602 BIOS
i7-9700k
2 x HyperX DDR4-4133
2 x SAMSUNG NVMe 960 EVO sitting on DIMM.2-Card
What i've reached so far:
The Samsungs appear under Advanced - NVMe, but i cannot build a RAID. U cannot select them. I attached 2 Screens.
Can u plz help me? Any ideas?7757477575
Additional Info:
There is 1 Card in PCIEX1_1 and 1 Card in PCIEX16_3
4 SATA-Drives are connected, too: In Ports 1,2,5 and 6.
10 REPLIES 10
G75rog
Did you look in the User, Bios, and Raid Configuration manuals for your MB?
Refer to page 4-1 it says to go here.https://www.asus.com/Motherboards/ROG-MAXIMUS-XI-EXTREME/HelpDesk_Manual/
Download this
Version E14794
2018/09/21 update 4.58 MBytes
RAID_Configuration_Guide User’s Manual ( English )
DOOMy
Yes, i had a look on all manuals and i have followed all of these guides, and on my M-9-APEX i had a running RAID, but on my new M-11-E it won't work. As you can see, the disks appear in nvme-configuration, but i can't select them in RAID-Configuration. I guess, it is only a little step...but i can't see it 😞
btrach144
Why are you running them off of PCI cards and not directly from the PCH M.2 slots?
Anyways, if you're going to do that, you need to go to Advanced>CPU Storage Configuration and set the PCIE slots to PCIE X4 SSD Card.
DOOMy
There is no Menu "CPU Storage Configuration" 😞 The Manuals also doesn't show this menu.
Have you tried to disconnect all Sata drives then set up tried with only the nvme drives? I can not check my self still waiting for my nvme drives to get here.
DOOMy
Did test all your tips now at home...nothing changed...under nvme configuration i can see the 2 disks, but under create raid volume i got a "no disks available"
dingo99
RAID is a PCH chipset feature. DIMM.2 is connected directly to the CPU. You need to use the M.2 slots connected to the PCH.
DOOMy
Jepp...found the same: On my M9A it worked, because DIMM.2 was connected to the PCH. On the M11E the DIMM.2 is connected to the CPU - so no RAID!
THX for all your help!!!
