Asus GL12CP - memory stick problem
FrancoisWolf
Hi !
I have a problem I have two 4GB ram RAMs mark :
SkHynix 4Gb 1rx16 PC4- 2666V-UC0-11 (4Gox2) so I've 8Go bright memory
I wanted to go to 16GB so I bought two Corsair Vengeance LPX memory sticks :
Corsair Vengeance LPX 8Go (2x4Go) DDR4 2666MHz C16 XMP 2.0 Kit de Mémoire Haute Performance
But I have a problem my ASUS recognizes only two memory modules is 8GB in the BIOS I have 8GB clocked 2133Mhz I do not have the option XMP (BIOS 309)
But CPU-Z detected 4 mémory sticks !
Can you help me please !
cl-Albert
US Customer Loyalty Agent
Welcome to the forums!
Sorry for the confusion, but as mentioned on the ASUS global site below (you need to scroll to see the GL12CP specs), the GL12CP only supports 2 memory sticks even though your motherboard may include 4 memory slots.
All 4 memory slots should normally be working, but only 2 will work at the same time.
https://www.asus.com/Tower-PCs/ROG-Strix-GL12/Tech-Specs/
