Results 1 to 4 of 4
    ROG Guru: Orange Belt Array
    Mar 2013
    35
    339
    asus oc panel compatibility
    anyone know if the oc panel will work with the x299 chipsets? i did notice there are boards with the rog extension header but wanted to make sure it was still working
    ROG Enthusiast Array
    Oct 2015
    42
    Yep, works on VI Apex and on VI Extreme. Got it working on both.
    Mar 2013
    35
    339
    awesome thank you
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    OC Panel
    OC Panel II
    Scroll down to the bottom of each page to see which ASUS motherboards are compatible.
    They each have firmware updates which extend their compatibility across other ASUS motherboards, you'd have to read whatever documentation might be provided with each firmware version to see if your X299 is supported.
    [/Korth]
