Results 1 to 10 of 13
12-18-2018 09:36 AM #1
mitropower PC Specs Motherboard Asus ROG RAMPAGE V EXTREME Processor Intel Core i7 5930K Memory (part number) Kingston HyperX Predator Black 32+16GB 3000MHz DDR4 Graphics Card #1 Asus GeForce RTX 2080 ROG Strix OC Sound Card Realtek High Definition Audio Monitor Asus ROG PG279Q Storage #1 Samsung SSD 840 PRO 512Gb Storage #2 Samsung SSD 830 512Gb CPU Cooler Cooler Master Nepton 280L Case Cooler Master HAF 932 Advanced Power Supply Silverstone Strider Platinum 850W ST85F-PT Keyboard A4Tech KV-300H Mouse Logitech G700s OS Windows 10
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 5
Funny business with PCI lanes on 9900k
Ok,
I am planning an upgrade of my rig (specs on left), and coming from 5930k with 40 lanes, all this business with 9900k having only 16 lanes is a real downer. Since I am not really keen on giving extra 500e for 9900X, because 5930k did not cost 1000e and had 40 lanes, I am looking at some options to get a rig better than I already have without selling my organs.
I am looking at Extreme XI, it attracted my for its DIMM.2 among other things. And I am a bit concerned that DIMM.2 riser card only seems to work directly on PCI lanes taking away 4x.
One of the things I plan on doing is going SLI and that will already push my GPUs config into x8/x8, if I also use DIMM.2 that will then push my cards into x8/x4 (how the hell does Intel consider 16 lanes CPU an enthusiast gamer CPU is beyond me).
So, ultimately can the riser card be redirected to use PCH instead? And even if so, how is that a good things? Is Maximus XI really not a good solution here because it will effectively offer lower performance to SLI customers because CPU ****blocks it? My train of thought is that if I use PCH for M.2 in order to dedicate CPU lanes to GPU, what does this board really offer that a lower priced does not (Formula is 50e cheaper, Hero half the price)? What am I not seeing?
12-18-2018 10:11 AM #2
x-rated PC Specs Motherboard Asus ROG Maximus XI Formula - Intel Z390 Processor Intel Core i9-9900K @ 5 GHz Memory (part number) G.Skill Trident Z F4-3600C16D-16GTZR - 4x 8 GB, 4 GHz, 18-18-18-38 Graphics Card #1 Nvidia GeForce RTX 2080 Ti FE - 2,1/15,6 GHz Sound Card Creative Sound Blaster X-Fi Titanium HD Monitor Dell UP2715K - 5120x2880, AH-IPS, 10bit Storage #1 Sabrent Rocket - 4 TB, 3 GB/s Case Fractal Design Define R6 Blackout TG Power Supply Corsair HX1000i - 1 KW, 83 A, 80Plus Platinum Keyboard Logitech G810 Orion Spectrum Mouse Logitech G403 Prodigy Wired Headset Sennheiser HD 660 S Mouse Pad Razer Manticor OS Windows 10 Pro Network Router Huawei HG8245H @ 1 Gb/s FTTH GPON Accessory #1 EKWB Velocity + Vector Accessory #2 EKWB XRES 140 Revo D5 PWM + 2x CoolStream XE 360 Accessory #3 6x Noiseblocker NB-eLoop Fan B12-PS
- Join Date
- Aug 2015
- Reputation
- 11
- Posts
- 203
i think that dimm.2 wont use any of dedicated pcie lanes from cpu to vga, it will use the capacity from one memory channel as pcie x4
and there is almost no real difference (if any) between x8 and x16 on vga - i didnt notice that unless i saw gpu-z (i had sound card in the second slot for vga)
12-18-2018 10:19 AM #3
Menthol PC Specs Motherboard M 10 Apex / XI gene Processor 8700K / 9900K Memory (part number) 2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500 Graphics Card #1 RTX 2080ti / GTX 1060 Sound Card SoundBlaster Ae5 / Onboard Monitor BENQ 32" 4K Storage #1 Intel 900p 480GB/Samsung 960 Pro 1TB Storage #2 Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro CPU Cooler Corsair H150i AIO / H1110i Case Corsair 740 ? Lian Li Air Power Supply Corsair AX 1200i / AX 1200i Keyboard Corsair Mouse ASUS Strix Headset HyperX Cloud Alpha Mouse Pad ASUS Headset/Speakers Logitech Z906 OS 10 X64 Pro Network Router Verizon Fios Accessory #1 Intel Wifi BT pcie card Accessory #2 Red Bull Accessory #3 English Breakfast Tea
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
Any drives on DIMM.2 module will operate off the CPU, they cannot be changed.
Nvidia cards requires x8 lanes minimum, SLI will not operate at x4 like AMD cards
SLI support in games has been dwindling, hardly worth it unless you have a specific game that you cannot live without that requires SLI for playable frame rates at 4K.
You will not notice the difference in drive speed off the PCH compared to off the CPU in any normal use case. You will only see the difference in disk benchmarks and then very minor
A single 2080ti or Titan RTX would be a better choice than 2 lower end cards, and if you need 2 2080ti's a X299 or Threadripper system is a better choice
12-18-2018 05:16 PM #4
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 5
Yea, figured as much, just wanted to check first. It's so bizzare what Intel is doing. I guess its finally time to see what AMD has to offer.
12-18-2018 06:05 PM #5
panzlock PC Specs Laptop (Model) ASUS X553M, ASUS Zenpad 10 Z300M, ASUS X542BA-DH99 Motherboard ASUS P8Z68-V LX, ASUS Z170-A, ASUS ROG Strix B350-F Gaming Processor Intel i5-2500K, Intel i7-6700K, AMD Ryzen R7 1700 Memory (part number) 8GB Kingston 1333MhzDDR3 C9, 16GB G.Skill Aegis 3000Mhz DDR4 C16, 16GB G.Skill Trident Z 3200Mhz C16 Graphics Card #1 EVGA GTX 560Ti, ASUS ROG Strix GeForce GTX 1070 O8G OC, Sapphire Nitro+ RX Vega 56 Monitor 32" INSIGNIA 720p, 32" Samsung 1080p C32F391FWN, 32" ASUS 1440p VA32AQ Storage #1 Seagate 150GB 7200RPM, Samsung 850 EVO 250GB 2.5" 6Gb/s Solid State Drive (X2) Storage #2 Seagate 500GB 7200RPM, WD Blue 3TB - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch CPU Cooler Deepcool GAMMAXX 300, Deepcool Lucifer V2, Wraith Spire Case Antec Sonata, Deepcool Dukase V1, Deepcool Dukase V3 Power Supply ATX 650, EVGA SuperNOVA 850 P2 (X2) Keyboard Logitech K220, MSI Interceptor DS4200 (X2) Mouse Microsoft 1850, Microsoft 4500, Gamdias Erebos LE, MSI DS 100, Redragon M601 Centrophorus Headset/Speakers Logitech Z313, Logitech Z506 (X2) OS Windows 10 Home X64, Windows 10 Pro X64 (X2)
- Join Date
- Nov 2016
- Reputation
- 54
- Posts
- 702
Even an R7 2700 will be sufficient for your needs with 20 PCIe lanes. Mind you I agree, there's little good argumentation for SLI or Cossfire except bragging rights. "Look what I got, mutha futha!"
I'd like to deploy my troops in her country.
12-19-2018 08:20 PM #6
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 5
12-19-2018 08:35 PM #7
- Join Date
- Mar 2015
- Reputation
- 10
- Posts
- 72
Hey - Mind if I hijack your thread? I think I understand what you are saying and I'm looking for possibly the same answer...
I'm moving from a 5930k / Maximus V Extreme to the XI Extreme with a 9900k - but I"m running SLI 2x1080ti's was going to go with a 970 EVO PRO Series NVMe...
is that not possible with this CPU?
(Sorry I haven't built a machine / followed hardware for awhile - except for GPUs...)Last edited by BossJ; 12-19-2018 at 08:38 PM.
12-19-2018 08:52 PM #8
- Join Date
- Aug 2015
- Reputation
- 11
- Posts
- 203
you can run both cards in x8 mode
12-19-2018 08:53 PM #9
- Join Date
- Mar 2015
- Reputation
- 10
- Posts
- 72
12-19-2018 09:02 PM #10
- Join Date
- Aug 2015
- Reputation
- 11
- Posts
- 203
SSDs can use another 24 lanes available from PCH
