12-18-2018 01:11 PM - last edited on 03-06-2024 07:31 PM by ROGBot
12-18-2018 08:06 PM
12-19-2018 12:05 PM
jondoe1989 wrote:
Hi there, I have the same card.
hmmm, if you aren't crashing or seeing any artefacting with games or benchmarks (furmark, timespy etc) - it probably means u got a good Chip, or ur ambient temperature is really cool. The "boost clocks" for the 3 settings 1890 (OC), 1860 (gaming) and 1830 (quiet) are just targets which the card will try to boost to, within their set thermal and power limitations. The frequency will boost even higher if the temperature allows, and how much this is possible depends on each individual chip, no two will the same.
I think if the temps are good, and you arent having and BSODs, crashes or artifacts, you may have won the chip lottery!
Perhaps someone can correct me if i'm wrong.
