Issue with my NVMe
dusty459
right i have a
Samsung 960 PRO 1TB M.2 2280 Internal SSD
and im noticing it Slow i used Samsung magician and tested
77694
i just dont get why anyone having an issue?
9 REPLIES 9
davemon50
Level 11
I have that model, and no issues (knock on wood). Have you checked for a firmware update?
Davemon50
dusty459
Hi Yes its up to date i just dont get why im getting its not working correctly
If you installed Samsung Magician then be sure to check if the driver was installed also. Had to manually point to the drivers in the Samsung folder to update mine.
Drive should also have a negative irq assignment since it should be in msi mode.
JustinThyme
It’s not drivers. The NVMe driver has been native since Win 8.1 and works perfectly. I’ve tested this over and over on several platforms and any differences are within the margin of error and can sway back and forth as many times as you run the bench.*
Don’t know what MOBO you are running but I would check a few things.
1) make sure it’s not sharing bandwidth with other devices.
In the BIOS
2) make sure it’s set to X4
3) check PCIE speed is set to gen3 and not auto
Lastly if this is a new install and you have background apps running it will destroy any bench. Particularly drive indexing which will settle down after some time. Could be hours or a day or two depending on how many files you have. *
I have the Zenith
JustinThyme
Have you checked your PCIE speed and lane allotment in the *BIOS and that it’s not sharing or indexing or AV running when you bench it?*
Also download and run crystalbenchmark and can that unmagical magician as it’s only decent use is the migration tool. *
Looking at your speeds I would call it as running at X2 and PCIE gen 2*
and i have the nvme pluged into77918
Iv also made sure that
pci is x4
gen 3 on cpu link and pci is gen 3 not auto
here are the results
CrystalDiskMark 6.0.1 x64 (UWP) (C) 2007-2018 hiyohiyo
Crystal Dew World : https://crystalmark.info/
* MB/s = 1,000,000 bytes/s [SATA/600 = 600,000,000 bytes/s]
* KB = 1000 bytes, KiB = 1024 bytes
Sequential Read (Q= 32,T= 1) : 3375.529 MB/s
Sequential Write (Q= 32,T= 1) : 2113.204 MB/s
Random Read 4KiB (Q= 8,T= 😎 : 1719.355 MB/s [ 419764.4 IOPS]
Random Write 4KiB (Q= 8,T= 😎 : 1070.717 MB/s [ 261405.5 IOPS]
Random Read 4KiB (Q= 32,T= 1) : 380.896 MB/s [ 92992.2 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 123.132 MB/s [ 30061.5 IOPS]
Random Read 4KiB (Q= 1,T= 1) : 54.328 MB/s [ 13263.7 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 166.764 MB/s [ 40713.9 IOPS]
Test : 1024 MiB [C: 18.6% (177.3/952.0 GiB)] (x5) [Interval=5 sec]
Date : 2019/01/02 17:49:39
OS : Windows 10 Professional [10.0 Build 17134] (x64)
dusty459
Sequential Read (Q= 32,T= 1) : 3298.267 MB/s
Sequential Write (Q= 32,T= 1) : 2017.975 MB/s
Random Read 4KiB (Q= 8,T= 😎 : 1714.797 MB/s [ 418651.6 IOPS]
Random Write 4KiB (Q= 8,T= 😎 : 1062.231 MB/s [ 259333.7 IOPS]
Random Read 4KiB (Q= 32,T= 1) : 382.829 MB/s [ 93464.1 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 310.186 MB/s [ 75729.0 IOPS]
Random Read 4KiB (Q= 1,T= 1) : 52.795 MB/s [ 12889.4 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 145.077 MB/s [ 35419.2 IOPS]
Test : 1024 MiB [C: 18.7% (177.6/952.0 GiB)] (x5) [Interval=5 sec]
Date : 2019/01/02 16:49:28
there is the results and i can't find the m.2 in the bios i see the other harddrives but where it says m.2 nothing
