Results 1 to 1 of 1
    New ROGer Array
    Dec 2018
    1
    Question ASUS Dual 2080ti - Fans max out @ 75c
    When the temprature reaches 75c on my card the fans start to behave really strange. The fans, 90% of the time fan1, starts to jump between normal usage and max. This keep going on for as long Im playing. The temprature stays between 72-76c when im gaming.
    I have had the card for 2 months and started to notice this behaviour the last couple of days.
    Ive tried reinstall drivers with DDU and tested older drivers. Even if i set a fan profile to never use more then i.e 70% of fans before 80c this is ignored.
    My solution so far has been to either lower the Power Target (%) or set the fans really high so I never reach 75c.
    Anyone have any idéa about this?
    An example image from GPU tweak. https://imgur.com/a/hk2CsWz
Tags for this Thread
