Page 13 of 36 FirstFirst ... 3 11 12 13 14 15 23 ... LastLast
Results 121 to 130 of 356
  1. #121
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 7980XE Custom IHS @ 4.6Ghz 1.23v
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1AORUS GeForce RTX™ 2080 Ti XTREME WATERFORCE WB 11G
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 512gb
    Storage #2Samsung 850 Evo 1TB x 2
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master Vanguard Series 1000W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Quote Originally Posted by JustinThyme View Post
    Just because some vendors are not educated very well doesn't change anything. That's like saying watching the trees go by out the window of your car is the same as a speedometer. One indicates movement, the other measures it.
    Flow indicator= simple hamster wheel.
    Flow meter = measurement of actual flow
    If you just want to see the hamster wheel moving then who is to argue your preference. Me, I want to know how much flow is actually happening as with a visual hamster wheel only that binds up and has jerky movement (they all do sooner or later) I cant tell if I'm pumping 5L/Hr or 500L/Hr. I bought the bitspower that is a flowmeter and has an output, still have it sitting on a shelf as a reminder of what not to do. To get it to move it takes and insert that chokes down the flow to create high pressure to get the hamster wheel to move. With the orifice out, the wheel doesnt move. With it in there is more flow from a gnats butt hole. The orifice chokes it down to less than half of a G1/4 fitting.
    I always as a rule of thumb check product specs to make sure there are no mistakes or marketing fluff because that happens a lot with everything. If its still not clear Ill contact the vendor before making the purchase and nail them down to guaranteeing what they have listed. Ive had some tell me they dont have the item and cant inspect it so they cant guarantee anything......so guess who doesn't get my business.If you cant stand behind what you sell, at least what its sold as then I refer to that as scamming.
    As for huge as digital display, I just took a close photo for clarity. Its much smaller than the TT meter you referenced about 2 inches long and 1 wide, not much different from the Rock you referenced at 1.5x1.5 inches and the build is far better than the TT contraption.
    No one is questioning your preference, just stating that the Rock is not a flow meter more for clarification of someone else that might look and think that based on your post that it is.
    I will say that the rock will not restrict flow like the bits power does as from I can see there are no orifices.
    I'm just stating a fact there naming conversion isn't always correct so call it what you want, Rock or Stone at the end of the day I do not care and as for you opinion I didn't ask for it, like I have said I don't want a digital meter as long as I can see its spin rate thats all I need its not rocket science.
    There are also some Flow indicator that have a RPM header so you can see the RPM of the spinner but like I said I'm happy with the basic.
  2. #122
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Cheese and rice dude, putt on the brakes. Getting a little offensive aren't we?
    This is an open fora and opinions are 99% of the posts, take the info or leave it.
    No matter how you slice it the two are different in every way shape and form. Just because some cant get it right doesn't change that. Its not rock or stone, Its flowers and boulders.
    I was just pointing that out and went way out of my way to make it clear no one is knocking your choice you can use what you want, its your rig. No one said in any way that what you want to do with your rig is wrong or right, its what you want.
    Other people read posts looking for information and I just pointed out that what you referenced in not a flow meter. This is 100% irrefutable fact. To offer up alternatives for the 7 billion other people on the planet is not saying you should use what you dont want to.
    In the end we all build what we want. You like the wheels on the bus going round and round, I like knowing how fast the bus is going. Neither is right or wrong, just different preferences. We would all still like to see it when you get done.
    Now If we can move on please to monoblock discussoins that would be awesome! Im done with flow indicator discussion.
  3. #123
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Then contact the manufacturer and stop wasting my time lol anyways back on topic now.
  4. #124
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    It was helpful to see both sides. I didn't know about the flow meter that tells you flow rate. I'm gonna check that out. Thanks for posting that
  5. #125
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    So I'm back guys, with the chopper ISH with LM I haven't done any Overclocking yet just happy to have my system up and running with the new 7940x.
    heres after a few runs of Cinebench check out these stable temps with minor jumps between them, this just shows the monoblock has no issues its just the IHS after delidding.
  6. #126
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    Processor7980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2417H
    Storage #1Intel Optane 900P
    Storage #2Samsung 970 EVO Plus
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    79
    1,354
    Quote Originally Posted by LiveOrDie View Post
    It's with the copper IHS of rockit ?
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme
    CPU: i9 7980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 900P
    DATA: Samsung 970 EVO Plus
    SOUND: Asus Xonar Phoebus
  7. #127
    Official EKWB Rep Array
    Nov 2018
    27
    12
    Quote Originally Posted by Abaidor View Post
    The Rampage VIE monoblock is really nice to look at and in my case has worked great for the last 8 months on a non-delidded i9-7940X. However, I am going with direct die cooling now so this cannot possibly be made to work without the IHS.
    Yet, even when delding it is going to be a hit and miss and contact will depend on the any height differences of the IHS (before/after delid) because of resealing or not and the amount of silicon applied. However, the whole point of delidding is to reduce the thickness of the thermal interface material (paste vs LM) in order to increase thermal performance. And as such, if the IHS is lowered beyond a certain point there is no way to achieve perfect contact with the IHS - AND - THE VRMS!
    We have an angle here, small or big, that will exist no matter what vs going with a dedicated CPU block that can be spring loaded.
    So I have ordered 2X EK Velocity blocks to use in two PCs and the second was because I wanted the D-RGB version that came 20 days after I bought the first. It would be great for your customers to offer the D-RGB frame as a standalone upgrade instead of having to buy a new block to get the addressable leds. I got a second one because I need two but otherwise I did not really like the fact that I can't buy the LEDs separately. We are in the custom watercooling community and these things should be given..
    At some point, we will actually be offering the different sections as standalone pieces to order. Not sure of an ETA yet though. Sorry
  8. #128
    ROG Guru: Orange Belt Array Abaidor PC Specs
    Abaidor PC Specs
    Processori9-7940X
    Memory (part number)F4-3600C17Q-64GTZR | Trident Z RGB 64GB
    Graphics Card #1Asus Strix 1080Ti OC
    Storage #1Samsung 960 Pro 512GB
    Storage #2WD 10TB Gold
    CPU CoolerEK Rampage VI Monoblock
    CaseC0smos 2 Modded
    Power SupplyCorsair AX1500i
    Abaidor's Avatar
    Dec 2017
    12
    259
    Quote Originally Posted by EKJake View Post
    No problem with ETA - it just happened that I bought too close to the D-RGB version release but since I am buidling another PC too I got the second one and problem solved. The reason I suggested that though is because it is possible since the RGB pcb is separate so whenever you release it I may grab one for the second block along with any other items I might need at the time.
    I am glad that you are reading our comments and considering them too. Although I have been absent for several years from the water cooling scene I've been an EK custom since the days of nVidia 8800GTX when I bought two GPU blocks from EK back then. When I returned to water cooling action a year ago things were totally different and the "EK" company a different "beast" along with the rants that follow such a transition. Lately though I am under the impression that EK is making an effort to connect with their customers again in more efficient ways than in the recent past...keep it up and focus on quality is what I have to say.
    Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
  9. #129
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS x99 sabertooth & x299 Rampage VI Apex
    Processori7-5930k & i9-9940x
    Memory (part number)Trident-Z 3200C14 & Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block & Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Coolerx99 2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 & EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum & Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Heatkiller IV Pro plexi/ Copper base on both systems
    Accessory #2 Mayhems Biocide and Inhibitor with distilled water
    Accessory #3 Mayhems 3/8-5/8" clear soft tubing
    ThrashZone's Avatar
    Oct 2017
    13
    271
    Besides looks a separate vrm water block will likely preform better than any mono block will especially on the cpu end being separate.
    Been there done that mono blocks on wall of shame
  10. #130
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    Now shoot the juice to it.
    *Either you are under locked or have some cores disabled as my cinebwnch scores on my 7900 match that and my 9400x is 1000 point higher.*
