Page 15 of 36 FirstFirst ... 5 13 14 15 16 17 25 ... LastLast
Results 141 to 150 of 356
  1. #141
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Mouse Pad Corsair MM800
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,336
    Quote Originally Posted by LiveOrDie View Post
    Yeah I just lent a delid tool off a local forum member and just paid postage, the rest of stuff I already had seeing this was my 4th CPU I've done, if you cpu has already been delidded you don't need the tool at all just keep that in mind to.
    You should restate that, "If I alraedy delidded it _I_ don't need a redelidding tool. I'm not sure what adhesive was used by Silicone lottery to put it back together and I THINK they used liquid metal as the TIM. I have neither. Quite honestly without some sort of guide with the delidding tool. I'm afraid I wouldn't get the CPU back on right. Maybe I could work something out with SL if I sent my CPU back with this copper IHS sink they'd just slap it on?
    While I'm not expecting 10 degrees cooler on all cores, i'm hoping to bring the outlying cores more towards the rest of the group when under load.
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
  2. #142
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 10980XE 4.6Ghz 1.12v WC
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1EVGA RTX 3080 XC3 ULTRA EK WB/BP
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 1TB
    Storage #2Samsung 860 Evo 1TB x 3
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master V 1300W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Haha yeah, I'm pretty sure if you asked them what they used you could work around it and I'm pretty sure they just tac the corners on, as for the relid guide you coild make your own pretty easy.
    10c max between cores I wouldn't say is abnormal, 15c+ then there is something wrong there for sure.
  3. #143
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,855
    SL actually uses some pretty heavy duty sheet and its all the way around. Some scorn them for this saying it causes heat retention. They defend their position with keeping the liquid metal from seeping out.
  4. #144
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Quote Originally Posted by JustinThyme View Post
    Then no wonder there CPU temps are crap lol.
  5. #145
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS z490 maximus XII Apex 2nd x299 Rampage VI Apex
    Processori9-10900k & i9-9940x
    Memory (part number)Trident-Z 3600c16 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 ModmyMods clear coolant
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    23
    389
    Quote Originally Posted by Brighttail View Post
    I and another member redid a SL delid
    It was fun but really all that is needed is a heating gun and razor blade and patience
    Posted here with images this forum is so restrictive with image size easier to post a link than try and upload one probably
    Oops looks like ocn is playing hide and seek again they do not like bad reviews of silicon lottery or EK for that matter being around
    Here's my 7900x opened up that SL delidded
    They said high temps are normal lol not !
  6. #146
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Quote Originally Posted by ThrashZone View Post
    Holy **** that's a mess lol the main point of delidding is to remove the silicon not to add more LMAO, did you end up cleaning that up? that's way to much LM O_o.
    My 7940x seems like a lemon 4.5ghz on 1.19v so far, tried for 4.6ghz but 1.25v wasn't even stable sad times.
  7. #147
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    389
    Clean as a whistle :thumb:
    SL leaves the Intel crap too which is why they use a lot of LM and it drips/ runs down over time and shipping is their excuse for the excessive amount and mono block compatibility they use ups slinging packages around like a Frisbee doesn't help
    Either way my temps were totally out of line all silicon lottery said it was normal and they do not recommended redoing it I wounder why lol
    They did however finally say they would redo the delid for more money of course but by then I totally lost confidence in their ability to actually redo it since they were aliment it was normal so I did it myself.
    A lot better now
    I've also found using offset or adaptive offset I have some "I call lazy cores"
    One of which is one that Intel is calling the best with the * tag
    Once I dial that lazy core which uses less vid than many others and also the second * tagged core is it stabilizes a lot better
    My VID's can vary by 0.025
    Lowering that gap can help quite a bit or really raising the low vid closer to the others and lowering the highest a little too sort of split the vid differences.
  8. #148
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    A lot better now
    That's good to hear, yeah I've tried adaptive on my 7940x and some cores run between 1.23 - 1.28v and there's no way to even them out it seems, I try to test with a manual voltage then try to setup adaptive but with that time of jump I mite have to stay with manual.
  9. #149
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    389
    That's good to hear, yeah I've tried adaptive on my 7940x and some cores run at 1.25v others at 1.28v and there's no way to even them put it seems, I try to test with a manual voltage then try to setup adaptive but with that time of jump I mite have to stay with manual.
    Just logged into overclock.net and indeed my silicon lottery thread was totally wiped out lol their bias is overwhelming obvious
    EK negative feedback too unfortunately.
    Yeah that's a large gap to close
    Maybe a redo on the sl delid will help that vid gap.
    Only good thing I noticed about mono blocks it showed the water jet horizontal instead of vertical
    I use horizontal now it seems top help a little on 7900x anyway the chip is a rectangle not a square.
  10. #150
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2417H
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 970 EVO Plus
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    109
    1,637
    I will test Rockit's IHS Copper well, but I would like to be sure to have a temperature gain (and not really want to retry the Direct Die too)
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 970 EVO Plus
    SOUND: Asus Xonar Phoebus
