Page 3 of 36 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 356
  1. #21
    ROG Guru: Orange Belt Array Abaidor PC Specs
    Abaidor PC Specs
    MotherboardRampage VI Extreme
    Processori9-7940X
    Memory (part number)F4-3600C17Q-64GTZR | Trident Z RGB 64GB
    Graphics Card #1Asus Strix 1080Ti OC
    Storage #1Samsung 960 Pro 512GB
    Storage #2WD 10TB Gold
    CPU CoolerEK Rampage VI Monoblock
    CaseC0smos 2 Modded
    Power SupplyCorsair AX1500i
    Abaidor's Avatar
    Dec 2017
    12
    260
    Quote Originally Posted by feedmeink View Post
    I run 4.6 at 1.17 and 4.8 at 1.23. I prefer to stay below 1.2 so I backed it down. I dunno. I really don't have any problems
    I think it really depends on the convexity of the IHS and this must not be the same across all CPUs. Maybe I give it a try but most certainly there is no way that it performs better than Standalone block & direct die cooling. It looks better I guess but I am designing something to make the transition pretty...lol.
    Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
  2. #22
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    Can't beat direct die. I'm sure it will work out good. I've never done direct die before. Been too paranoid I would crack the PCB lol. Plus I see a lot of complaints about the LM not reacting well with direct contact to blocks.
  3. #23
    Abaidor PC Specs
    Processori9-7940X
    CaseC0smos 2 Modded
    Abaidor's Avatar
    Dec 2017
    12
    260
    Yet, even with "Kyonaut" paste it would still be better than with the IHS. You are removing an extra thermal layer after all. Now to avoid cracking the die, you need on of those direct die frames and of course a lot of care while mounting.
  4. #24
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    Please update with OC and thermal difference after you direct die. I'm very interested in seeing the difference.
  5. #25
    Abaidor PC Specs
    Processori9-7940X
    CaseC0smos 2 Modded
    Abaidor's Avatar
    Dec 2017
    12
    260
    I will do so but the damn thing has no ETA besides a 16/01/2019 which is not even certain.....I have it back-ordered and paid for since the 20th of November.....All the other items are here (delid tool, liquid tape, new waterblocks, new fittings for hard tube, tubes, RGB led strips / Halos...).....all these goodies and I can't proceed because of the freaking frame!
  6. #26
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,855
    Looking forward to your DD post. Might get a microATX and yank the lid back off my 7900X to see if I can go past the 5GHz brick wall and run two systems in the same case or just leave it in a test bed. I’d like to get a pair of 2080TIs but not at the price point they are going for. 1080TI still beats 2080 by a good bit and I got mine before the darn crypto mining got out of control and seriously killing the consumer market segment. *All greedy. One would think they would limit the miners purchases so the rest of the world can get GPUs. When you get these outfits cleaning out entire supplies in one click it kills more than the GPU market. Who wants to spend for the lastest hi res games when you can’t get a card to run them?
  7. #27
    ROG Guru: Orange Belt Array rjbarker PC Specs
    rjbarker PC Specs
    MotherboardMaximus XI Extreme (BIOS 0605)
    Processor9900K @ 5.1 Ghz w EK Velocity
    Memory (part number)32 GB -Dominator Platinum 3200 Mhz CAS 16
    Graphics Card #1Evga RTX 3080 FTW3 Ultra w FC EKWB
    Sound CardOnboard Realtek
    MonitorDell Alienware 34" Ultra wide 120Hz Gsync
    Storage #1Samsung 970 Pro 512G M.2 NNMe
    Storage #2Samsung 860 Pro 512G & 256G
    CPU CoolerEK Supremacy Copper w Nickel Plating
    CaseCorsair 900D
    Power SupplyCorsair AX 1600i
    OS W10 HP x64 - 20H2
    Accessory #1 480 * 360 * 240 XSPC Radiators (15 Fans) w 4 Channel 200W Fan Controller
    Accessory #2 XSPC Photon Rez / Vario Pump combo
    Accessory #3 Fesser Flex Tubing - Bits Power Fittings & EK SLi Terminal
    rjbarker's Avatar
    May 2013
    16
    291
    Quote Originally Posted by JustinThyme View Post
    I was seriously looking at replacing the 1080Ti's with 2080Ti's...(need SLi my OCD)..but north of $4K for 2 GPU's and Blocks is ridiculous!!!! nv really put the screws to us this generation.....as you said there are no options out there to replace a 1080Ti right now except a $1.7K Card .....sure hope this price isnt the norm now....I got my 1080Ti's before the Crypto Mining craze as well.....$875 CAD .....makes me cringe looking at the cost of the new Cards....used to be the Titans that were ridiculously priced....now the Ti's .....
  8. #28
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 10980XE 4.6Ghz 1.12v WC
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1EVGA RTX 3080 XC3 ULTRA EK WB/BP
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 1TB
    Storage #2Samsung 860 Evo 1TB x 3
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master V 1300W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Once i get my pad ill be pulling my system apart for some testing before putting it back together if i have to delidded my CPU again and fix the issue with the gap ill do it.
  9. #29
    ROG Member Array zoobzone PC Specs
    zoobzone PC Specs
    Laptop (Model)MacBook Pro 15" Touchbar 2017
    MotherboardASUS ROG Rampage VI Apex
    ProcessorIntel Core i9 7900X
    Memory (part number)GSKILL F4-3200C14-8GTZR
    Graphics Card #1GTX1080
    Graphics Card #2GTX1080
    MonitorAcer Predator X34
    Storage #1Samsung 960 EVO
    Storage #2Western Digital 2TB Green
    CPU CoolerEKWB Customloop with EKWB RVIE Monoblock
    CaseEVGA DG-87
    Power SupplyEVGA P2 1200W
    Keyboard ASUS ROG Claymore RGB Cherry-MX Blue
    Mouse Mionix Naos 7000
    OS Windows 10 Pro x64
    zoobzone's Avatar
    Oct 2017
    21
    I see that no one has mentioned the rockit custom IHS plate, they made it with increased height that accounts for the decrease from delidding.
    I'm actually considering delidding and putting the custom IHS on, as I'm currently running 7900X with the EK monoblock at 4.8GHz on my best core, rest cores are 4.6GHz without delid. Temperatures are alright but occassionally the 4.8GHz core does hit 90 degrees.
  10. #30
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,855
    Heat has alaways been the issue. Difference in height is just another reason not to use a monoblock. They have a specific distance they sit off the motherboard that can’t be changed without meticulously removing the stand offs them you have to also look at the fact that this will decrease the distance on the VRM end of it. Using a separate blocks alleviates this as a CPU only block floats on the IHS and held pressure from springs. The his attribute of a monoblock is something I never did care for.*
