Page 31 of 36 FirstFirst ... 21 29 30 31 32 33 ... LastLast
Results 301 to 310 of 356
  1. #301
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 7980XE Custom IHS @ 4.6Ghz 1.23v
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1AORUS GeForce RTX™ 2080 Ti XTREME WATERFORCE WB 11G
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 512gb
    Storage #2Samsung 850 Evo 1TB x 2
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master Vanguard Series 1000W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Quote Originally Posted by tistou77 View Post
    Several "OCers" told me the opposite, better than CL for copper
    But I do not use "copper" so no worries
    There's a reason they sell LC on there site and not grizzly.
  2. #302
    ROG Guru: Yellow Belt Array xarot PC Specs
    xarot PC Specs
    Laptop (Model)Asus GL504GM
    MotherboardAsus Rampage VI Extreme
    Processori9-7980XE
    Memory (part number)Corsair Dominator Platinum 64GB CL16-18-18
    Graphics Card #1Palit RTX2080TI
    Sound CardIntegrated
    MonitorAsus PG279Q
    Storage #1Intel 750 1.2 TB PCIe
    Storage #2Samsung 960 Pro 1 TB
    CPU CoolerEK Supremacy EVO Full Nickel
    CasePhanteks Enthoo Primo
    Power SupplyCorsair AX1500i
    Keyboard Blackstorm Mech RGB
    Mouse Steelseries Rival 310
    Headset Sennheiser HD555
    Mouse Pad Razer Goliathus Extended
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    181
    I also removed my direct-die frame but that was only because I changed my loop and couldn't use QDCs directly on the waterblock anymore.
    When comparing, the direct-die definitely had lower temps, running Prime95 SmallFFTs and the hottest core is good 4-5c hotter after only 10 mins in with the IHS and seeing the same on other cores too. But at 4.5 GHz my loop of 480+360 rads was running out of juice already even with the direct die. So using the same 4.4 GHz now as before. Just a few degrees hotter.
    Also noticed previously I ran my EK block in the 90 degree orientation with direct die. Noticed that the LM "stain" was not exactly at the center of the block base looking from either sides? Dunno how that's possible, but would definitely make the mounting more difficult. Of course the block base was painted by myself, but it still seemed off..
    Gaming: i9-7980XE H2O - Rampage VI Extreme - 64 GB Corsair Dominator Platinum DDR4-3200 - Palit RTX2080TI H2O - Phanteks Enthoo Primo - Corsair AX1500i - Intel 750 1.2 TB - Samsung 960 PRO 1 TB
    HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1070 - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
    All around: i7-9900X H2O - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX2060 - In Win 101C - Samsung 960 EVO 512 GB
  3. #303
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Is not nickel version ?!
    So I order one of these and installed it on my XE and temps are pretty bad, I've order some new LM to retry next weekend as one core seems really good the others aren't so much, these temps are from 4.5Ghz OC on 1.2v
  4. #304
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme
    Processor7980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2417H
    Storage #1Intel Optane 900P
    Storage #2Samsung 970 EVO Plus
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    79
    1,354
    Quote Originally Posted by LiveOrDie View Post
    Ok, not yet had the time to try on my side
    Normally it should not be worse than the Copper version
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme
    CPU: i9 7980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 900P
    DATA: Samsung 970 EVO Plus
    SOUND: Asus Xonar Phoebus
  5. #305
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    I'm hopping its just the LM or the thermal paste the next time i redo the paste ill be applying it to only the bottom of the mono block rather than the IHS.
  6. #306
    tistou77 PC Specs
    MonitorDell U2417H
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    79
    1,354
    New Grizzly pad for CPU
    Someone has already tested ?
    https://www.caseking.de/thermal-griz...-zuwa-180.html
    Case: Lian Li A77F
    CPU: i9 7980XE
  7. #307
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Those pads have been around for years there not as good as paste.
    What are your VRM temps like? i redid my CPU temps didn't change there the same after new LM and paste, locked to 1.2v i can't go higher on this XE the heats to much.
  8. #308
    tistou77 PC Specs
    MonitorDell U2417H
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    79
    1,354
    My VRMs are ~ 50, 54 ° according to stress tests
    With the IHS "nickel" the temperatures are less good or the same as with the copper IHS ?
    Case: Lian Li A77F
    CPU: i9 7980XE
  9. #309
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    Its hard to tell because this CPU has more cores and uses more power, but I don't think my temps are to good.
  10. #310
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    I don't think this IHS is transferring the heat as well as a stock IHS, I think i might test the stock IHS or just put the copper one back on, I got idle temps of 20c and lower on the copper IHS 29c is the lowest idle i see.
