Page 35 of 36 FirstFirst ... 25 33 34 35 36 LastLast
Results 341 to 350 of 356
  1. #341
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2417H
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 970 EVO Plus
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    109
    1,637
    Hello
    I finally found the time to test the IHS Nickel (Rockit): D
    Only compared with Cinebench (3 tests in a row and took the temperatures of the last tests, room temperature identical to 1°)
    Cinebench R15 (IHS Stock / IHS Nickel (Rockit))
ID:	80778 Click image for larger version.
Name:	CB R15_IHS.PNG
    Cinebench R20 (IHS Stock / IHS Nickel (Rockit))
ID:	80779 Click image for larger version.
Name:	CB R20_IHS.PNG
    I am happy
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 970 EVO Plus
    SOUND: Asus Xonar Phoebus
  2. #342
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 10980XE 4.6Ghz 1.12v WC
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1EVGA RTX 3080 XC3 ULTRA EK WB/BP
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 1TB
    Storage #2Samsung 860 Evo 1TB x 3
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master V 1300W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Quote Originally Posted by tistou77 View Post
    Hello
    [ATTACH=CONFIG]80778[/ATTCH] [ATTACH=COFIG]80780[ATTACH]
    [ATTACH=CONFI]8077[/ATTACH] [ATTACH=CONIG]8781[/ATTACH]
    I am happy
    ebay has a better nickel IHS now its lapped.
  3. #343
    tistou77 PC Specs
    MonitorDell U2417H
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    109
    1,637
    Quote Originally Posted by LiveOrDie View Post
    you've tested ?
    Link ?
    Some have tested the Ebay IHS and no difference with the original IHS
    Case: Lian Li A77F
    CPU: i9 10980XE
  4. #344
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    you've tested ?
    Link ?
    No these are new IHS's being made they have the tabs on the sides and are better, I have ordered one will change it out soon.
    LINK
  5. #345
    tistou77 PC Specs
    MonitorDell U2417H
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    109
    1,637
    LINK
    Ok thanks
    Tell us the difference between IHS Nickel of Rockit and that of Ebay
    Case: Lian Li A77F
    CPU: i9 10980XE
  6. #346
    ROG Guru: Yellow Belt Array xarot PC Specs
    xarot PC Specs
    Laptop (Model)Asus GL504GM
    MotherboardAsus Rampage VI Extreme
    Processori9-7980XE
    Memory (part number)Corsair Dominator Platinum 64GB CL16-18-18
    Graphics Card #1Palit RTX2080TI
    Sound CardIntegrated
    MonitorAsus PG279Q
    Storage #1Intel 750 1.2 TB PCIe
    Storage #2Samsung 960 Pro 1 TB
    CPU CoolerEK Supremacy EVO Full Nickel
    CasePhanteks Enthoo Primo
    Power SupplyCorsair AX1500i
    Keyboard Blackstorm Mech RGB
    Mouse Steelseries Rival 310
    Headset Sennheiser HD555
    Mouse Pad Razer Goliathus Extended
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    198
    Where did you buy the Rockit IHS to EU? The shipping costs are really steep from their website to Finland.
    I've spent quite a bit of money trying to cool my 7980XE. Direct die, bartx IHS, etc, still using original IHS now. Direct die was better but the maintenance is something I hate with it (if I need to pull the waterblock for maintenance etc). I wish it was just soldered to begin with so I couldn't bother with this.
    Main: Xeon W-3175X - Dominus Extreme - 48 GB Corsair Dominator Platinum DDR4-3200 - Palit RTX2080TI H2O - Phanteks Enthoo Primo - Corsair AX1500i - Samsung 960 PRO 1 TB + Intel 600P 1TB
    HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1070 - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
    All around: i7-7980XE - H150i Pro - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX2060 - In Win 101C - Samsung 960 EVO 512 GB
  7. #347
    tistou77 PC Specs
    MonitorDell U2417H
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    109
    1,637
    Directly on their site, it is true that the shipping costs are as expensive as the product (for Europe)
    They told me that their products would be distributed by Amazon in the future
    Case: Lian Li A77F
    CPU: i9 10980XE
  8. #348
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Quote Originally Posted by xarot View Post
    Are you after a nickel plated version? if you interested I can send you mine as i don't use it at a discount.
  9. #349
    xarot PC Specs
    Processori9-7980XE
    MonitorAsus PG279Q
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    198
    Actually can't find the nickel version on the website, only copper. Was it a limited batch or something? :O
  10. #350
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    The nickle version isn't listed no and you have to ask for it after ordering.
