Page 36 of 36 FirstFirst ... 26 34 35 36
Results 351 to 356 of 356
  1. #351
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 10980XE 4.6Ghz 1.12v WC
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1EVGA RTX 3080 XC3 ULTRA EK WB/BP
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 1TB
    Storage #2Samsung 860 Evo 1TB x 3
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master V 1300W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    I've picked up a cheap Omega board so ill be moving away from the mono block to a EK Velocity once the IHS comes.
  2. #352
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Quote Originally Posted by tistou77 View Post
    Ok thanks
    Tell us the difference between IHS Nickel of Rockit and that of Ebay
    Temps are way better the ebay IHS is lapped when the Rockit isn't also this IHS has better temps than the copper one I had, but take note I sanded my die down flat it really helped my higher temp cores, also temp would be lower if TJ was 105c like it use to be. Also I'm not sure they will make more of this IHS it was limited edition.
    Temps in yellow you can see how most temps are close to the copper rockit IHS but some are a lot lower due to sanding, but overall the ebay IHS is on par with the copper version not rockit's crappy nickel plated one.
  3. #353
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2417H
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 970 EVO Plus
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    109
    1,640
    Thanks so much for your feedback
    IHS Nickel of Ebay is equal to IHS Copper of Rockit therefore, between 1 and 3° earned approximately (without sanding)
    You've sanded the DIE of CPU, right ?
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 970 EVO Plus
    SOUND: Asus Xonar Phoebus
  4. #354
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Yeah so the ebay nickel plated preformed on most 1c hotter than the copper rockit cool IHS, the gray temps are the nickel plated rockit IHS which is just poor in performance overall, yes die is sanded so surface is flat, for LM the ebay nickel IHS is the one to buy.
  5. #355
    tistou77 PC Specs
    MonitorDell U2417H
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    109
    1,640
    Ok thanks
    I would not sand the DIE (too scared)
    I'm going to keep the Rockit IHS, without sanding, I do not have much to gain
    Case: Lian Li A77F
    CPU: i9 10980XE
  6. #356
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Ok thanks
    Only sand if you feel like your able to do it without killing your CPU, for my CPU it really needed it plus i got this CPU 2nd hand so was only half what you would of paid.
