Results 1 to 3 of 3
    ROG Member Array
    Mar 2014
    7
    b360-i gaming works great..annoying white led!
    So I built my dream computer a couple of months ago using this mobo and everything has been working great, but because my case has a side glass panel for the lightshow I also see one of its few glaring flaws. It seems that when ever the motherboard boots up using the integrated gpu the status light remains white.. and not just white but brighter-than-the-sun white. The thing is, I have a 1080gtx.
    It seems to only happen if I do a restart without powering down, or I turn my pc on before I turn on the stereo receiver it passes through on. I have tried toggling everything in and out of the bios to tell the pc to ignore the igpu and always use the pci-e vga device but it doesn't listen. Anyone have a solution before I break out the electrical tape?
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Is this light on the GPU? Like near the power connector? If so this is actually normal and should be there when 5V standby is available. I’m surprised if it goes out. If this isn’t it and you have narrowed it down to a restart will make it go out then disable fast start up.*
    You have my interest on what it is. I have annoying red ones on my DIMM.2 that aggravate me. Found that the tits on a LEGO cut off with a dremmel and a *dab of silicone covers those puppies up and no more red. Board has lots of others but I don’t like seeing a red Led as that makes me think something is wrong. **
    ROG Member Array
    Mar 2014
    7
    This is the status light in the upper corner of the mobo near the ram. It changes colors depending on the current POST code. White means the iGPU is in use (or no pci graphics found). Likewise when this happens, I do not see the ROG boot logo on the screen but as soon as windows starts, windows is on my screen, but the white led never goes out.
    I like your lego tits method, I would hate to use a marker for fear of shorting traces, and black tape never stays on.
