Results 1 to 8 of 8
    ROG Enthusiast Array walrbe PC Specs
    walrbe PC Specs
    MotherboardMaximus XI Hero
    Processori7-8700K
    Memory (part number)G Skill TridentZ RGB F4-3200C16-8GTZR
    MonitorPhilips BDM3270
    CPU CoolerDeepCool Castle 280 AIO
    CaseFractal Design R6
    Power SupplyAntec Gamer power 520W
    OS Windows 10Pro
    Nov 2018
    43
    8700K OC temps at 5.0Ghz how should I interpret the temps?
    I'm running 5.0ghz I'd like to ask how to evaluate core temps with the various tests? When using intel burn test my temps arehigh 80's deg C with some cores hitting 91C. When running OCCT its sits on mid 60's the only difference I see is OCCT is running clock at 4.8Ghz because of the CPU Offset for AVX. My core voltage is 1.296V max. I'm using Deepcool 280 AIO. I did try 5.1Ghz briefly but got high 90's using Aida64 so I backed off.
    I'm guessing I could try 5.1Ghz again but with slightly lower voltage 1.35V was making it too hot. I'd appreciate your insight. thanks
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    498
    13,501
    RealBench was created pretty much to skip around this kind of problem. It uses much more holistic/realworld testing and if your system can pass its stress test then it's probably all good for 24/7 use.
    Other stress tests simply don't test in the same way...all hammering away at one subsystem for unrealistic temperatures and loads. In fact they often pass doing just the one type of test and then the system fails running a game...
    I'd also point out that there is a point at which 100MHz increase simply brings virtually no return in performance and a whole lot of return in temperature and current degradation of your CPU
    Check out my OC guide in sig
    ROG Guru: Yellow Belt Array x-rated PC Specs
    x-rated PC Specs
    MotherboardAsus ROG Maximus XI Formula - Intel Z390
    ProcessorIntel Core i9-9900K @ 5 GHz
    Memory (part number)G.Skill Trident Z F4-3600C16D-16GTZR - 4x 8 GB, 4 GHz, 18-18-18-38
    Graphics Card #1Nvidia GeForce RTX 2080 Ti FE - 2,1/15,6 GHz
    Sound CardCreative Sound Blaster X-Fi Titanium HD
    MonitorDell UP2715K - 5120x2880, AH-IPS, 10bit
    Storage #1Sabrent Rocket - 4 TB, 3 GB/s
    CaseFractal Design Define R6 Blackout TG
    Power SupplyCorsair HX1000i - 1 KW, 83 A, 80Plus Platinum
    Keyboard Logitech G810 Orion Spectrum
    Mouse Logitech G403 Prodigy Wired
    Headset Sennheiser HD 660 S
    Mouse Pad Razer Manticor
    OS Windows 10 Pro
    Network RouterHuawei HG8245H @ 1 Gb/s FTTH GPON
    Accessory #1 EKWB Velocity + Vector
    Accessory #2 EKWB XRES 140 Revo D5 PWM + 2x CoolStream XE 360
    Accessory #3 6x Noiseblocker NB-eLoop Fan B12-PS
    x-rated's Avatar
    Aug 2015
    11
    203
    Quote Originally Posted by walrbe View Post
    the most important temps are in apps you use other tests are just for more stability check purposes, if you don't use them on daily basis at 110+°C, there's nothing to care about
    walrbe PC Specs
    Processori7-8700K
    OS Windows 10Pro
    Nov 2018
    43
    Yeah thanks, good points.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    91C is getting a bit warm. TJ max on that chip is 100C where it will commence to throttling. I’d say so long as you don’t leak much past 90 *with a peak of no more than 95 your good.*
    As already stated by Arne the wise realbemch is a better bench that actually uses a combination of real loads and not just hammering the cores for all they are worth non stop. Put that on a loop for 15 mins and it should saturate your AIO as far as it’s going to go. *
    x-rated PC Specs
    OS Windows 10 Pro
    x-rated's Avatar
    Aug 2015
    11
    203
    Quote Originally Posted by JustinThyme View Post
    it can be adjusted in bios to 115°C
    this is useful when temperature in some doomsday tests like prime95 with AVX enabled spikes beyond 100°C to prevent this throttling
  7. #7
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    What are you guys talking about 100+ degree temps, that's crazy talk, get better cooling or tune it down a little, I don't like to see 80 degrees with the heaviest load, 90 and I'm done with that test
  8. #8
    walrbe PC Specs
    Processori7-8700K
    OS Windows 10Pro
    Nov 2018
    43
    Quote Originally Posted by Menthol View Post
    Couldn't agree more, a test is just that a test and getting temps up to the 90's is pushing it I understand but that's the only way to see how the chip is performing. I do appreciate that something like Realbench or OCCT are more realistic testing tools and that gives me comfort on where my particular CPU can sit at. Especially for my application of my PC.
