Results 1 to 6 of 6
    ROG Member Array
    Dec 2018
    6
    GeForce RTX AI Suite GPU Temp Fan Xpert & GPU Tweak do not work
    I recently upgraded from my 1080 Ti Strix to the 2080 Strix. I also have an Asus Motherboard and I used to run my case fans with gpu temps. But now with my 2080 Strix it does not work anymore. At the beginning, when I just installed the 2080, Fan Expert recognizes GPU temps and gives me the opportunity to choose GPU temp instead of CPU temps as source for case fans. But it didn't apply. It kept on the lowest fan speed and if temps reach next level of fan speed, nothing happened. So I reinstalled everything. Nvidia drivers & AI Suite. Now AI Suite and Fan Xpert not even show me GPU temps and opportunity to choose GPU as a source.
    Is Fan Expert not compatible yet with new RX series or is it my cards fault?
    I also have problems with GPU Tweaks external fan courve. My 1080 Ti gave me a range of 32-100% fan speed. But with the 2080 Strix it is broken. When I start auto fan calibration he shows me after secons a range of 0-100% but does not apply them. I only can run at least with 50% fan speed.
    Can anybode who owns a RTX tell me if he has same problems or not?
    Thanks for answers!
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardCrosshair VIII Dark Hero
    Processor5900X 4.6ghz All core 1.3V, 5ghz single DOC
    Memory (part number)Gskill NEO 3600 CAS 14 32GB (4x8)
    Graphics Card #1ROG Strix RTX 3080
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 980 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 980 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks 500A Mesh
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur Virtuoso
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    994
    I am on the other thread but will post here as well to increase awareness (although I believe Asus is well aware). This problem is not RTX specific. Happens with my Strix 2080 Ti, Strix 1080 Ti, and FE Titan X. I can select the GPU temp in Fan Expert, I can SEE the GPU on AIS front panel below in temp section, but GPU temps do not control the fan on the set curve.
    ROG Member Array
    Dec 2018
    6
    Ok really interesting how different the expierences are. With my 1080 Ti it used to run great. But now after upgrading its so broken. Cant even bring GPU temps back with my 1080 Ti after uninstalled and reinstalled. Really sad.
    New ROGer Array
    Jan 2019
    2
    GPU Temp on Z390 Strix and RTX 2070
    I have a ROG Strix Z390 Gaming-E board and a MSI 2070 RTX Armor 8G and wanted to get a ROG Strix 2070 OC 8G instead to be able to control the chassis fans with the 2 fan headers on the 2070 RTX according to the GPU temp but have read from several users that fan xpert 4 / AI Suite III can not do that...
    I tried setting AI Suite alone to control CHA1 fans on the mainboard according to GPU temps but it just shows N/A and does not change the fan speed.. the GPU fans themselves are controlled by MSI Afterburner and that works well.. still I wanted to get the GPU temp to control the front chassis fans so getting an ASUS ROG Strix 2070 RTX seemed to be a solution with the 2 onboard fan headers but it looks like fan xpert can not read the GPU temp...
    It's a shame when you buy top of the line stuff from the ROG Strix line and then have to deal with bugs in the software..
    New ROGer Array
    Jan 2019
    2
    Question
    Is there any fix planned from ASUS on that? I'm kinda disappointed that getting a ASUS ROG Strix Z390 Gaming-E mainboard and a ASUS ROG Strix 2070 RTX 8G OC will not instantly work together as intended for controlling fans chained to GPU temps...
    ROG Junior Member Array Mathaeum PC Specs
    Mathaeum PC Specs
    MotherboardASUS ROG Strix Z270F
    ProcessorIntel Core i5 7600K 3.80 Ghz
    Memory (part number)G.Skill Trident Z RGB 3000 Mhz
    Graphics Card #1NVIDIA RTX 2060 Founder Edition
    MonitorASUS MX25AQ
    Storage #1SSD Crucial MX300
    Storage #2Seagate Barracuda 7200 rpm 64 MB
    CPU CoolerCooler Master MasterAir 610P
    CaseCooler Master MasterCase Pro 6
    Power SupplyCooler Master MasterWatt Lite 700
    Keyboard Cooler Master Masterkeys
    Mouse Razer Abyssus V2
    OS Microsoft Windows 10 x64
    Jan 2018
    1
    Hello,
    I have the NVIDIA RTX FE and in the software suite I can't control the T of the GPU because there isn't the panel of the graphic card, even in the section on the main screen of the Ai Suite 3. After I upgraded my GPU seems the Ai suite wont recognise the card.
    I have the latest NVIDIA drivers and the system is up-to date.
Tags for this Thread
