Results 1 to 7 of 7
    New ROGer Array
    Dec 2018
    2
    Asus G752VS very bad sound quality
    Hello, I just got my new gaming laptop but it has very bad sound quality. Sometimes it just starts to make sounds randomly, probably a driver bug.
    How can I make that stop and how can I increase the sound Quality?
    Thanks
    ROG Guru: Orange Belt Array
    Nov 2012
    55
    478
    The best Realtek driver I use on my G752VSK is version 6.0.1.8443.
    New ROGer Array
    Dec 2018
    2
    why can i give my replys own titles lol
    I tried that already. The only thing that has worked so far is the standard windows audio driver. But when I use that one I have three audio devices. First is the subwoofer, second the small speakers behind the display, third the digital audio jack.
    Nov 2012
    55
    478
    Try installing the original audio driver from your eSupport Folder first, then upgrade to the latest Realtek driver.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Laptops in general lack the depth of sound we’ve come to take for granted. Reminds me of my younger years and small handheld transistor radios.*
    The G752 went due south regardless of the model. The previous G751’s gave a better experience but it’s still a laptop. My recommendation? Forget the onboard audio and use a Bluetooth speaker, some of which sound surprisingly good and yet are still portable with far more battery life than the laptop can achieve.**
    ROG Member Array AtomicStryker PC Specs
    Laptop (Model)G752VS
    MotherboardASRock Z170 Extreme4
    Processori5 6600k
    Memory (part number)16GB
    Graphics Card #1GTX 1080 @ watercooled
    MonitorAW3418D
    Storage #11TB Samsung Evo 850 Nvm
    CaseCoolermaster Cosmos
    Power SupplyCorsair RM650X
    Keyboard Logitech G710+
    Mouse Logitech G502
    Headset/Speakers Marantz SR6010 + DALI Opticon 5.1
    OS Windows 10 x64
    Accessory #1 Mo-Ra 2 Radiator
    Accessory #2 Magicool Pump
    Oct 2016
    14
    You can try using the Sonic Studio software - i found that when i cranked up several of the config options (i think bass, clarity...?) the sound got slightly better. It's still unusually bad for a laptop IMO.
  7. #7
    ROG Member Array
    Nov 2015
    6
    For the record.
    I tried to install some updated drivers and they give me a lot of troubles and the audio sounds AWFUL (like underwater)
    So we need to uninstall all drivers then install the drivers from scratch:
    First, uninstall the driver of the audio Device Manager > Sound, video and gaming controller -> uninstall Realtek audio driver (if you can, then mark the option to uninstalls the drivers)
    Then (in the menu),Device Manager -> view -> show hidden devices.
    Then Device Manager >Audio inputs and outputs> uninstall everything marked as (Realtek(r) audio). It uninstalls the drivers for the speakers.
    And finally:
    a) you could install the drivers for your notebook or, if it fails then:
    b) you could install the default (Realtek) drivers then, over them, the drivers for your notebook
