Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Guru: White Belt Array
    Oct 2012
    96
    Question 2x Samsung 970 Pro 1To (NVMe) in RAID 0 less good than without raid...?
    Hello all
    I just bought 2 NVMe Samsung 970 Pro 1 To to make an raid 0 on the Asus Maximus XI Extreme (chipset Z390) last drivers (i let the original RST OROM, i just update the Intel ME Firmware to the 1,5Mo v12.0.10.1127).
    I fault by doing this raid 0 i will have a better speed... But it worst than an 1 970 Pro alone without raid...
    like you see here they make an test of the 970 Pro (version 512Go):
    https://www.guru3d.com/articles-page...review,15.html
    except for the write Seq Q32T1 i have a very bad speed compare to the non Raid 970 Pro...
    my setting an bench (sorry for the french):
    https://files.homepagemodules.de/b60...2_mFCEsYBH.png
    the manual of my motherboard show that : (i am little lost about, wich option is connected with the cpu or chipset and if it is the reason of my speed problem...)I make many test in a cold computer or runing since 1 hour, is a fresh windows 10 pro with all last drivers and last bios 0602 (except the RST OROM)
    https://files.homepagemodules.de/b60...3_YeqDKBVo.png
    thank you
    thank you
    Oct 2012
    96
    please clic on the 2 last link to display the Screenshots. (the forum dont want to display them automaticaly...)
    ROG Member Array
    Jun 2016
    17
    16
    Did you disabled c-states in BIOS?
    Did you set Windows 10 to Highperformance mode on energie options?
    hmm is the dmi on z390 still limited to PCI-E x4 aka 4000mb/s?
    Oct 2012
    96
    hi
    yes c-states disabled
    yes windows 10 high performence mode
    the rest i dont know, i dont except that after all the money i send on the motherboard, the 9900k and the 2 970 pro of 1To.... i am very sad. i hope is a solution becaue is no sence to be in raid 0 if 1 970 pro have better speed (i dont test it but watching the different bench)
    ROG Guru: Yellow Belt Array Guitarmageddon888 PC Specs
    MotherboardMaximus x code bios1704
    Memory (part number)8700k 5.1/4.9avx
    Graphics Card #1MSI 2080 gaming trio
    MonitorHP Omen 27"
    Storage #1Samsung 970 m.2
    Storage #2Samsung 860 evo
    CPU CoolerH150i
    CaseLian li pc011
    Power SupplyEvga supernova g3 850w
    Keyboard Corsair k70
    OS Windows 10
    Nov 2018
    12
    192
    High performance power preset affects storage speed?
    ROG Guru: Yellow Belt Array Ch3vr0n PC Specs
    Ch3vr0n PC Specs
    MotherboardAsus Maximus XI Formula
    ProcessorCore i9 9900k @ 4.7GHZ (XMP)
    Memory (part number)CMD16GX4M4B3200C16-ROG
    Graphics Card #1Asus Strix GTX 1080 A8G
    Sound Cardon board
    MonitorASUS VG278HR & ASUS VK278Q
    Storage #1Samsung 960 Pro 512 GB & 970 EVO 2TB
    Storage #23X HGST 10TB, 1x HGST 4TB
    CPU CoolerScythe Mugen 5 PCGH
    CaseCooler Master Cosmos II
    Power SupplyCorsair AX860i
    Keyboard Corsair k95 RGB Platinum
    Mouse Corsair M65Pro RGB
    Headset Corsair Voide Wireless SE
    Mouse Pad Corsair MM300
    Headset/Speakers Logitech Z-906
    OS Windows 10 Pro x64
    Network RouterNetgear XR500
    Accessory #1 Xbox One Elite Wireless Controller
    Accessory #2 2X Corsair LL140, 4x Corsair LL120
    Accessory #3 1x Corsair LED RGB Pro expansion kit
    Ch3vr0n's Avatar
    Nov 2012
    157
    There's 0 sense in raiding an nvme drive, in any shape or form. The max speed an nvme drive can deliver already maxes out the lane bandwith. Read spead in general will increase, but write speed will in most cases DECREASE.
  7. #7
    Oct 2012
    96
    dear Ch3vr0n why you said that ?...
    NVMe in raid 0 strip 64 or 128ko deliver gain...
    for exemple :
    http://i63.tinypic.com/2q2ltvq.jpg
    Guitarmageddon888 for energy saving who will probably not let max perf
  8. #8
    ROG Guru: Yellow Belt Array Deepcuts PC Specs
    Deepcuts PC Specs
    MotherboardAsus Maximus X HERO BIOS 1901
    ProcessorIntel i7 8700K @ 4.7Ghz 1.215V
    Memory (part number)CMR32GX4M4C3466C16 @ 3200Mhz 1.360V
    Graphics Card #1Asus Strix GTX 1080Ti OC 11GB
    Sound CardCreative Omni 5.1 USB
    MonitorDell 24' S2417DG
    Storage #1Samsung EVO 960 nvme 500 GB
    Storage #2Seagate NAS 8TBx2
    CPU CoolerNZXT Kraken X62
    CaseFractal Design Define R5 Black
    Power SupplyCorsair AXi760
    Keyboard Razer DeathStalker Chroma
    Mouse Razer Abyssus
    OS Windows 10
    Network RouterMikrotik
    Jan 2014
    13
    244
    Quote Originally Posted by Ch3vr0n View Post
    Would be nice to at least check before making such claims.
    For example: https://www.eteknix.com/year-nvme-ra...world-setup/6/
  9. #9
    Ch3vr0n PC Specs
    Sound Cardon board
    Ch3vr0n's Avatar
    Nov 2012
    157
    yeah and the only thing a human does all day is run performance benchmarks or check how fast 1 file opens 1 moment, and again 5 seconds later. Or compare how fast & file compresses on 2 different occasions. For normal use the average user will notice ZERO difference between raid and non-raid. There's a time when you hit diminishing returns. In fact when i moved my boot from an 850 EVO 2.5" sata to a 960 Pro nvme, can't say i noticed any difference.
    That's coming from personal experience.
  10. #10
    Oct 2012
    96
    @Deepcuts every one can make an mistake ^^
    Do you have please any solution to my problem ? is realy strange as we can see on my scree the 970 pro perform better alone than in my raid of 2 970 pro... i see crazy speed in other post with NVMe Raid 0... :/
    @Ch3vr0n
    thank you for your personal return experience but here is not the subject and this dosent help me.. please understand, happy christmas man
