Results 1 to 4 of 4
    ROG Enthusiast Array xator PC Specs
    xator PC Specs
    MotherboardASUS ROG Maximus X Hero WIFI AC
    ProcessorIntel Core i7 9900k
    Memory (part number)2x16GB Corsair Vengeance LPX 3000Mhz
    Graphics Card #1EVGA GTX 1080Ti SC2
    MonitorDell U2518D
    Storage #1Samsung 970 evo NVMe SSD 250GB + HP S700 SSD 250GB
    Storage #22x WD RED SATA 3 2TB
    CPU CoolerNoctua NH-D15S
    CaseCorsair 600C
    Power SupplyCorsair RM850X
    Keyboard Logitech K360
    Mouse Logitech M705
    Headset Sony MDR-XB650BT
    Headset/Speakers Logitech Z4 2.1
    OS Windows 10 Pro x64
    Accessory #1 Xbox 360 Wireless Receiver
    Accessory #2 Xbox One Wireless Adapter
    Jun 2013
    11
    53
    Post Line-Based vs. Message Signaled-Based Interrupts [ Possible Audio popping fix? ]
    Hi there,
    This post is a WIP since I'm still testing it out. As many of you may know, there's an issue on some systems, specifically Audio popping and crackling from z170 till z390. If you search through the forums, there's an endless discussion wether it's ASUS fault or Realtek's. Either way, none of them seem to be fixing it. There are some temporal fixes like disabling fastboot or so, but nothing really reassuring.
    I've come across some discovery on my system, and although I don't know if It will work on yours, I wanted to share this in case it helps to someone.
    BEFORE reading more, please know that YOUR SYSTEM MAY NOT WORK PROPERLY AFTER APPLYING THIS FIX, and I AM NOT RESPONSIBLE for any damage.
    PROCEED AT YOU OWN RISK.
    PLEASE, DO A SYSTEM RESTORE POINT BEFORE FURTHER TESTING.
    In case something goes wrong, you can always restore your system's registry back.
    I came across a forum from Guru3D, about how IRQs of onboard devices are being used by Windows. It turns out that, most of our system should be able to handle this by MSI mode, and not Line Based, which is the old way. This should improve latency radically.
    You can check if your devices are being used on Line-Based Interrupts, or MSInterrupts easy, just following this copy & pasted instructions from that forum:
    Code:
    Checking for PCI devices working in MSI-mode.
    Go to Device Manager.
    Click in menu "View -> Resources by type".
    Expand "Interrupt request (IRQ)" node of the tree.
    Scroll down to "(PCI) 0x... (...) device name" device nodes.
    Devices with positive number for IRQ (like "(PCI) 0x00000011 (17) ...") are in Line-based interrupts-mode.
    Devices with negative number for IRQ (like "(PCI) 0xFFFFFFFA (-6) ...") are in Message Signaled-based Interrupts-mode.
    So my audio device, in fact both of them, were on Line Based . So I forced them to MSI Mode using this steps:
    Code:
    Trying to switch device to MSI-mode.
    You must locate device`s registry key.
    Invoke device properties dialog.
    Switch to "Details" tab.
    Select "Device Instance Path" in "Property" combo-box.
    Write down "Value"
    (for example "PCI\VEN_1002&DEV_4397&SUBSYS_1609103C&REV_00\3&11583659&0&B0").
    This is relative registry path under the key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\".
    Go to that device`s registry key ("HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1002&DEV_4397&SUBSYS_1609103C&REV_00\3&11583659&0&B0")
    and locate down the subkey "Device Parameters\Interrupt Management".
    For devices working in MSI-mode there will be subkey "Device Parameters\Interrupt Management\MessageSignaledInterruptProperties"
    and in that subkey there will be DWORD value "MSISupported" equals to "0x00000001".
    To switch device from legacy- to MSI-mode just add these subkey and value.
    Then I rebooted and even with Fastboot mode on, there is no more audio popping or crackling on my end.
    Again, this fix is just WIP, and I don't even know if it is related with audio issues or not. I came across it accidentally, and I'm currently testing if it lasts. Also, If you want to switch your other devices to MSI mode, there's a easy TOOL made by the guy on the forum. Please, take a read as it is very interesting:
    Forum Thread Link
    I don't know if this link is allowed, so if It is not, please tell me and I'll remove it. I'm posting it as it's not my discovery, If it fixes something for you as well, credits go to mbk1969, from Guru3D.
    ROG Member Array
    May 2017
    6
    Going to try this now thanks.
    My Realtek, Nvidia 1080gtx ti, and Nvidia HD audio were all the legacy method. Hope this fixes some issues.
    xator PC Specs
    MonitorDell U2518D
    CaseCorsair 600C
    Mouse Logitech M705
    Jun 2013
    11
    53
    Quote Originally Posted by Yodogyodog View Post
    Same devices that I had on legacy. Since I posted that, I've had no issues with audio. Good Luck , and report back :-)
    New ROGer Array
    Dec 2018
    1
    Sound popping
    My "solution" is this: I restart my PC. On first start there's popping, crackling and desyncs (e.g. youtube videos). On restart there are no issues at all. It doesn't matter, if it's fast start or not.
    Does that make any sense to you guys?
Tags for this Thread
