AI Suite 3 And fans
DuskyShade
Hello
In my case I have 6 Thermaltake fans and all of them are connected to a TTSync controller.
The Aura works just fine, but I can't control fan speed individually.
I can only find "2 fans" but each of them represent all fans in the system.
How can I control the fans individually?
Mobo: ROG Striz z390-E
CPU: i5-9600k
GPU: GTX 1070ti
DuskyShade
Ok no worries solved it by myself lol.
I'll write here what I did in case someone will need it.
I realized I put the 3 intake fans in one side of the controller and the 3 exhaust fans in another side. Each side is connected to the motherboard via PWM.
I still can't control each fan individually but I can control intake fans and exhaust fans since they're on different connectors.
IDK why but even if the AI Suite identifies 2 connectors doesn't modify the options for each of them, instead changes the speed of all 6 fans.
I went to the BIOS and messed a bit with speed to check which fans correspond with which connector.
After I found out which PWM connector controlled which fan I could change the velocity and curve in the BIOS to my liking.
If someone knows other tips to control fan speed let me know!
