PCI Device / SM Bus Controller (Not found) XI Extreme
BossJ
I'm not sure what these are on my system...
I'm running a 970 Pro Series NVMe - and 2 1080ti's ... but I can't figure out these in my device manager.. I installed all the drivers and such...
Anyone know?
Menthol
Level 14
You can manually update in device manager, by pointing to you driver disk, or Windows update
If you have any issues you will need to supply all your hardware specs
I had the same problem & Windows will not find the drivers i tried numerous times, what you need to do as i did is download and run the following:
https://downloadcenter.intel.com/download/28182/Chipset-INF-Utility?product=1145
This will install the missing drivers.
SirWaWa
