GL553VD 120hz monitor upgrade, will it work?
terrybear2k
my gl553vd's warranty is coming to an end soon, so i'm looking to upgrade it's monitor
the current monitor is NT156FHM-N41, which is only 60hz
http://www.panelook.com/NT156FHM-N41_BOE_15.6_LCM_overview_27048.html
if i replace with B156HTN05.1 will it work? do i need to flash firmware or something?
http://www.panelook.com/B156HTN05.1_AUO_15.6_LCM_overview_31517.html
5 REPLIES 5
terrybear2k
nobody knows?
dran2
I asked same question couple months ago inspired by LTT, but I guess nobody tried this yet.
FULLMETALJACKET
Level 11
Good chances that It will work, but you will lose its Gsync capabilities. That's what happened with the GL502's, at least.
dran2
It does not have g-sync anyway.
cl-Albert
US Customer Loyalty Agent
Closing this thread since you can just check the thread below now.
UPDATE ON PREVIOUS POST "GL553VD 120hz monitor upgrade, will it work?"
Thanks.
