Results 1 to 1 of 1
    ROG Junior Member Array X0Reactor PC Specs
    X0Reactor PC Specs
    MotherboardMSI X370 Gaming Plus
    ProcessorAMD Ryzen 7 1700 OC @ 3.8Ghz
    Memory (part number)8 GB DDR4
    Graphics Card #1Asus Geforce GTX 1060 Dual OC 3 GB
    MonitorAOC 1080 17'
    CPU CoolerStock Cooler
    CaseJunk Case
    Power SupplyAntec 450W
    OS Windows 10 Pro
    X0Reactor's Avatar
    Dec 2018
    1
    Asus Geforce GTX 1060 Dual OC 3 GB fan curve
    Hello everyone, this is my first post here and I was wondering what would be a good custom fan curve for my card. My card idles at around 34c or 35c, it goes up a couple of degrees when I am surfing the web and so forth. My pc setup is Asus m5a78l-m/usb3, AMD FX 6300 black edition OC'ed to 4.5ghz, 8 gb DDR3 ram, master cooler 212 evo cooler and a junk case for the time being. Right now I have my custom fan curve set in MSI afterburner so the fan doesn't kick on until it reaches 45c and I have the fan % set to 45%, then when it reaches 50c I have it set to 50%. Is this good or bad? Edit: Also would it be a good ideal to keep my fans on my card running at 25% until it reaches 45C so as to keep the card cool?
