Error code
TheDragon
Hello, I am getting crashes in Dishonored 2 around the same area. The error code is: 0xC0000188, I have tried to fix it on my own but can't find the solution. Please help!
I am posting it here because I have no clue if it is something to do with my overclocking or not.
You are supposed to smear the cooling paste behind the CPU on the pins, right?
Menthol
Level 14
If you are not sure if it is your overclock set all settings to default values to eliminate the overclock, check Nvidia forums for your specific issue or forums for your specific game
