MAXIMUS XI EXTREME With G.Skill DDR4-4133 CAS 17
Andrew_WOT
I am using G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-4133 Memory, the one with 17 CAS
F4-4133C17D-16GTZR
https://www.gskill.com/en/product/f4-4133c17d-16gtzr
And cannot push it to 4133 using XMP profile, tried XMP1 and XMP2, PC just does not boot.
Tried to increase DDR voltage as well as system agent and VCCIO, no cigar.
Can run at 4000Mhz, but anything above it, even 4100, it just hangs on start up.
CPU is 9900K, tried stock and OC, same result.
Has anyone have any luck with these sticks, what's the secret?
Thanks in advance.
18 REPLIES 18
BossJ
I'm having the same issue with Model F4-4133C19D-16GTZR... Strange
The memory is on the Asus QVL ...so...it's been tested for compatibility...try booting with just a single stick....select XMP 1...set dram frequency to 4133mhz..leave IO/SA voltages on auto...(yes...they will be high)...if it boots successful...shut down...add second stick...reboot...again...if successful...reboot and lower IO/SA voltages...start with 1.28v...and lower.
4133mhz is not a guarantee...chips IMC plays a part time
Asus ROG Maximus XI EXTREME
Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
Swiftech Drive II / Swiftech MCP35X Pump
Enermax Platimax 1200 Watt Power Supply
32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
(5)Samsung 840 Pro 128 GB In Raid 0
(2) WD 1TB Black Edition
Corsair 900 D
You are not alone
https://rog.asus.com/forum/showthread.php?105993-Maximus-XI-Hero-and-G-Skill-4133-Mhz-Cl19-booting-p...
At 4000 MHz it seems to be stable, passing all MemTest86 stress tests. 😞
rjbarker
Level 11
Did you try setting up those sticks manually vs XMP ? Try that..with rated Timings and Auto for Sub Timings...ensure CR 2 ...try higher vDIMM manually (1.4v - 1.43v)...and as was pointed out IO / SA manually .....you simply may not get them to run at rated there rated.....
Andrew_WOT
Was looking for anyone successfully running them at the rated speed with that MB and what settings were used.
I think I have tried everything except full Manual.
What parameters should I set going full manual vs XMP.
Thanks everyone for your help. BTW, I am on the 0602 BIOS, and XMP profile is shown as 4140, which is kind of weird as DDR is rated for 4133. Wondering if that's matter as actual DDR speed in XMP profile is properly set to 4133.
I suspect it is more about your CPUs IMC than anything else. 4133 is a steep request of the CPUs memory controller. Will likely require full manual tweaks in the UEFI.
My thoughts exactly 😉
Is the BCLK @100.00 or 100.100?
Corsair 900 D
100.00
